Solved System idle process (using rediculous memory)
I see a problem right off the top, you have many, many open Chrome. Why are you using so many browser windows?
i only have 1 window up but may have 4-5 tabs up within that window. im not sure why chrome causes 5-8 processes, allways have for me, and chrome has nothing to do with it. i switched to chrome 1-2 days ago and ive had this problem for 2 weeks, had firefox before
How much free hard drive space do you have?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Do you have any type of synch or back ups between the two drives?
Is the drive with the smaller free space a SSD?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
That's confusing. You said you have 40 Gb free and 2 Tb on the other HD.
Is this a 3 Tb drive with two partitions?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
my c is a 100g partition of a 2 tb drive. my c has 47 gig free space and the rest of the drive has 40gig left, then i have 3 other drives. 1 usb connected drive for 1 tb wich isnt plugged in atm. then i have another 2 tb drive wich has 1.4 tb space left. then i have an old drive from my old computer wich is a 200gig drive with 173 gig left...
that clear it up i hope :geek:
Which drive is used for virtual memory and how much do you have set?
Is your system slow for other things other than watching series?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I don't think you can set virtual memory that high. I also wouldn't set it on a drive separate from your main hard drive.
Have you ever set it? If not, then Windows is managing it and I wouldn't worry about it. I thought maybe you had the virtual memory set to a large size that might be taking up space on your C: drive.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
My problem seems to actually have been solved... my nvidia driver scanner found today a new update to the drivers. and after installing that my memory has been going around 2.7gig ram for a few hours now.. so seems the problem was the previous beta driver update of my graphics card
We are glad that you got this sorted, I will mark this thread as solved.
Yep, yesterday a new graphics driver was released , glad you are solved. Thanks for using Vista Forums .
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
