SYSTEM BOOT FAIL PRESS f1 to continue
@roy 69
i really thank you for ur help.
well i have 3 friends who have a pci-e graphic cards.
well i cant install drivers manually because when i updated my drivers the device manager is no more showing the device connected in pci-e slot.
and i think that my motherboard has the problem...
can u tell me why the error comes
"SYSTEM BOOT FAIL PRESS f1 to continue"
if i am able to solve this problem then i will get to know which hardware is failing the motherboard or the powersupply....
    INTEL
    INTEL CORE 2 DUO
    ASUS P5NMX
    2.5 GB
    NVIDIA 9500GT
    REALTEK
    LG
    1024 x 768
    SEAGATE 250GB
    1 MBPS
To my knowledge, it won't show up. I just booted and my card doesn't show up.
If you install another card and boot, Windows should automatically find the Windows driver for it and install it.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
then y it is not showing up?????
what i need to do now???
    INTEL
    INTEL CORE 2 DUO
    ASUS P5NMX
    2.5 GB
    NVIDIA 9500GT
    REALTEK
    LG
    1024 x 768
    SEAGATE 250GB
    1 MBPS
Without looking at your system I can not tell you why the boot is failing, probably a bad driver.
Diagnostics is a fine art. Swapping out pieces is one sure way of doing it, Trying out your graphics card on your friends system for instance. However when you do this you also need to stress test it to ensure that it is working properly and does not just seem to work.
Get a pro to look at your mobo, it could be a bent pin insude your PCI-e port that is causing the problem.
Here at the forums we do our best to solve other peoples problems, however without being at the ops computer it can become hard to diagnose problems.
Have you had a look at your events.
Left Click on Start Menu.
Right click on Computer and choose manage.
Click on the event viewer.
You now have loads of options to try and pin down what is happening.
Expand the error tab.
Look for things in the last 24 hours.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
yeah i think the thing left is to go to a pro who can diagnose the problem.
anyways thx for ur help...u did a gr8 job to help me out.
    INTEL
    INTEL CORE 2 DUO
    ASUS P5NMX
    2.5 GB
    NVIDIA 9500GT
    REALTEK
    LG
    1024 x 768
    SEAGATE 250GB
    1 MBPS
If you do that, would you come back and let us know what the solution was?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
yeah surely i would let u know what actually happened....
    INTEL
    INTEL CORE 2 DUO
    ASUS P5NMX
    2.5 GB
    NVIDIA 9500GT
    REALTEK
    LG
    1024 x 768
    SEAGATE 250GB
    1 MBPS
Sorry to bump this thread, but I have the exact same problem with a P5N-MX and 9600GT. Did you find a solution in the end? I'm considering just buying a replacement mobo.
hey dude
I am just running my pc with the problem and i am unable to play games and I have not find any solution with this...
Do u also have the same problem???
plss mention symptoms of ur pc....
    INTEL
    INTEL CORE 2 DUO
    ASUS P5NMX
    2.5 GB
    NVIDIA 9500GT
    REALTEK
    LG
    1024 x 768
    SEAGATE 250GB
    1 MBPS
Well I'm running from the integrated graphics card. I've set the PCI-E to the default in BIOS and yet there's no signal from the graphics card. Like you, this means I can't play games, etc, etc
And on every startup it says there was a system boot fail (though not much else) and I have to press F1 to continue. I'm planning on getting a new motherboard. I've managed to find some cheap, old, socket 775, DDR2 ones so I don't have to get a new CPU, RAM etc.
same problem here dude...
add me on gmail so we can see what we can do further
    INTEL
    INTEL CORE 2 DUO
    ASUS P5NMX
    2.5 GB
    NVIDIA 9500GT
    REALTEK
    LG
    1024 x 768
    SEAGATE 250GB
    1 MBPS
A couple of suggestions:
1. Try setting the first boot device to the hard drive using the BIOS settings to see if you get the same error.
2. Try resetting the BIOS to the factory default.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
we have done all these experiments and even updated the bios and den also no solution this problem.....
    INTEL
    INTEL CORE 2 DUO
    ASUS P5NMX
    2.5 GB
    NVIDIA 9500GT
    REALTEK
    LG
    1024 x 768
    SEAGATE 250GB
    1 MBPS
Yeah, I tried all that kind of thing... I think I had the most up to date BIOS. I didn't try downgrading it. However, it failed POST on every startup so maybe the board was just plain broken.
I've replaced it with a new ASUS P5QPL-VM EPU mainboard and now everything's working just fine.
yeah finally the problem is solved
I went to a repair shop he told that main the main chip is gone so the board is gone and cannot be repaired and i got the new board
ASROCK G41M-VS3 r2.0 and everything is working fine
any comments on the new board???
one new problem is persisting that is my graphic card is not showing display on this board???
what is the problem ???
any guesses???
    INTEL
    INTEL CORE 2 DUO
    ASUS P5NMX
    2.5 GB
    NVIDIA 9500GT
    REALTEK
    LG
    1024 x 768
    SEAGATE 250GB
    1 MBPS
Don't know much about that board, sorry. But from the product code I'm guessing it has the Intel G41 chipset, which is the same as the board I got.
I don't understand. Isn't that the same problem you were having before?
Since this problem doesn't fit the subject of this thread, I recommend that you post the problem in the Graphics subforum where it will get more attention.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
earlier i didnt know that problem is in my motherboard and i have tried my graphic card in my frnds system and it was working fine and was not showing display in my old board because the main chip of the motherboard was gone
but it is not working in the new board ..
iss der any compatibility issue????
    INTEL
    INTEL CORE 2 DUO
    ASUS P5NMX
    2.5 GB
    NVIDIA 9500GT
    REALTEK
    LG
    1024 x 768
    SEAGATE 250GB
    1 MBPS
