Stdrt.exe
I thank you all for your input. My first post stated that Combofix had affected some of my settings. I also had the same thing happen when i used a Registry cleaner called Regcure. My printer had to be reinstalled. Its a Canon MP 480. I think this forum does a splendid job. I posted my problem on a few other Pc help sites and i only got one reply and that was to use Combofix. When it affected my printer i never replied but then i was running Avg Antivirus and was told to uninstall it while using Combofix. It lookslike some of AVG remailed on the computer as i had uninstalled from all programs and not the AVG cleaner. I will now do a factory reset and i daresay now that i have found you i will do has Arnold Schwarzenegger said "Ill Be Back" Thanks again.
    Acer Aspire T180 R01-A4
    1.80 gigahertz AMD Sempron
    Acer EM61SM/EM61PM
    1280 Megabytes Usable Installed Memory
    NVIDIA GeForce 6100 nForce 405 [Display adapter]
    High Definition Audio Device
    Medion MD32117PQ [Monitor] (17.1"vis, s/n 609001173, September 2006
