Static Coming From Speakers
Status
Not open for further replies.
Static on all PCI slots. Do you have on-board sound? Remove the sound card and see if it has static. Replacing the motherboard with a different one. This can be hit or miss. Trying another sound adapter.
    16GB DDR667
    SAS RAID
I removed my sound card and use a Logitech USB headset instead.
    16GB DDR667
    SAS RAID
Your parents might like the USB headset idea, when gaming.
    16GB DDR667
    SAS RAID
Best Buy, Circuit City. They go $20-$100 depends on what you get. Amazon or Newegg should have them.
    16GB DDR667
    SAS RAID
Man do I wish we had a Best Buy or a Circuit City. Lima has nothing, we have 4 walmarts, which is not needed. We have Office Depot and Office Max.
Ill see what i can find, Thanks for the idea.
Walmart will go down as the company that ruined the US.
    16GB DDR667
    SAS RAID
I have had a bit of static in my speakers this morning, a sort of crackling noise. I seem to have sorted the problem by just simply twisting the plug in the socket. This is usually enough to clean the contacts and ensure a good connection. Most cases of static are caused by poor connections and dust in the socket. Just remove the cover of your PC and see how much dust is in there. It is inevitable that some of this will find its way to the sockets. In fact, many PC faults can be attributed to poor connections.
Dwarf
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Thank You I will Clean out My Computer in a bit.... Now that i think about it, It has been awhile since i have cleaned the inside of it out. I Will tell you if this helps or not.
Dwarf, Do you think since i have a wireless keyboard/mouse that there might be some interference? Or my dad had some Ham Radios, Could that be it? Just a thought.
Thank you,
Aaron
If you hear static when hard drive is accessing or mouse moving, its in the bus.
    16GB DDR667
    SAS RAID
OK, well i moved the card, cleaned the entire inside of the computer.....NOTHING!!!!
Im beginning to think that it is just the speakers.
Update: I just unplugged the speakers from the sound card and then plugged the headphones straight into the card. It is the speakers that are making the static. Looks like i will need to just go get new speakers.
Hi Aaron,
Since the problem disappears when you use your headphones rather than your speakers, that eliminates problems with your PC. Let's look at your speakers. Are the interconnecting cables wired in or are they connected by plugs? If you have plug-in cables, try different cables. If they are directly wired, then you are probably looking at new speakers. However, you could try this (it also works for portable radios). With the speakers not operating, turn the volume control from minimum to maximum and back again a few times. It is possible that there is some contamination of the resistive track in the control. Try the speakers again. Even if that helps and the problem seems to go away, this is probably only a temporary solution. You would still be advised to replace your speakers.
Dwarf
    Gigabyte IF233
Ya i am most likley looking at getting a new set of speakers. They came with the Wireless Keyboard and mouse, so in they are not the best of quality, which is suprising because they are logictechs. But new speakers would not hurt.
Hi Aaron,
Pleased to hear that you have resolved your problem.
Dwarf
    Gigabyte IF233
Status
