Sound distorted and stuttering in windowed mode.
It sounds like it installed. Does it show up in control panel\sound or in Device Manager, Sound....
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
There's still only C-Media Audio Device and AMD HD Audio Device there.
I must note though, that the AC97 download is only for Windows XP and below on that site you provided.
In the last link I gave you for the ADi..... driver, you said it was for some driver update utility. When I tried it, I got a file called win57991.exe. Is that the same file you downloaded? Since my sound is working properly, I didn't want to run it.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
It's up to you but I would try uninstalling or disabling the Xear driver.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
The chipset driver is the AD...... one that we were trying to find without having to pay for a driver download program. We could still look for that. I don't know which OS this one is for- Asus Motherboard Drivers | Files | SoundMax ADI1986A Audio Driver V5.12.1.5430 | A8S X | Drivers | Game Front
Could you give me a screenshot of the Control Panel\Sound\Playback screen? Make sure that all disabled and disconnected devices are shown. You can do that by just right clicking in the white space on the screen.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
That's pretty sparse. There's no audio manager shown.
If you right click on the Speaker icon in the screen shot, what is the speaker configuration shown?
I'm a little bothered by the fact that the Xear driver uses Directx 10. Does your graphics card support Directx 10?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I getting pretty close to not knowing where to go next-
You're graphics card supports Directx10.
I still think it's a driver issue. I've seen problems with 3D video depending on whether or not the screen was maximized or minimized, in another forum. My best recommendation is to disable the Xear and install the Realtec AC97 driver. I don't know why your AMD was disconnected. I guess it had something to do with the computer repair.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Do you have any codecs installed like divX or Xvid? If so try to uninstall or reinstall them? Also from the start menu type in dxdiag. Look under the audio and video tabs to see if it finds any problems. Also check undo video that the directx accelerations are enabled.
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
    8 gb
    1 TB & 500 GB
If you go to Control Panel\Device Manager\Sound, .................., it should be there. If you right click on it, you should be able to disable it.
If the Realtek is shown, enable it.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
