7z920 is 7-zip version 9.20. It shouldn't cause any problems. However, you don't need it running at startup. Ditto for BitComet. If you've run a clean boot with all services except Microsoft disabled and all startup items disabled and the system is still sluggish, I don't know what to tell you. We already know that your hard drive is space limited and that can have a huge effect on how fast things happen. How long does it take from the time you press the power button to the time you see Windows loading (You know, the little green bar going from left to right and back).
Edit: I was wrong about the amount of hard drive space.
- Operating System
- Vista Home Premium 64 bit SP2
- Cyberpower
- Intel Quad CPU Q6700 2.67 GHZ
- NVIDIA 780i
- 4 GB
- MSI GTX 560 TI Twin Frozr
- Sound Blaster SB Audigy
- Viewsonic VG2436
- 1920x1080p
- Samsung HD 105SI WDC WD20
- Case
- Apevia XJupiter
- Cooling
- air
- Logitech MX 600
- Logitech MX 3200
- 30 Mbps
Everything seems to be running smoothly. I'll let you know if I have anymore problems.
I'm just not a pro at this.
