So it's gone from 231s to 236s to 226s and then to 87s?Sounds strange.
To be honest I doubt you'll get anything much faster than that with your computer specs. Your RAM is the minimum requirement for Vista. If it's really annoying you, then you could look into ReadyBoost (using USB devices as RAM basically):
Using memory in your storage device to speed up your computer
Also, here's a few tips you could do:
http://www.vistax64.com/tutorials/81176-speed-up-performance-vista.html
Especially these two:
http://www.vistax64.com/tutorials/70563-boot-up.html
http://www.vistax64.com/tutorials/70567-shutdown.html
Tom
I don't consider 1 gb to be the minumim requirements. It really should be 2 gb even if M$ only says one. I've never put stock in their minimum or even recommended amounts. Keep in mind that although Vista requires basically the same amount of ram as it did when it came out the programs people use on their computers have changed and usually those changes require more resources (especially ram) many of them also have smaller programs or services that they like to run all the time-even when the program isn't in use. Those cumulatively bog down windows and fill up your ram. In addition I notice on my desktop that eventually Vista starts to consume more and more ram. For example it is using up about 800 mb upon boot up (I have lots of stuff turned off) but after several days it'll be up to 1300 and not go down. You'll benefit immensely from more ram.
Yeah, thanks for pointing that out. I'm running 2GB at the moment and even that isn't very much
- Build #1
- Intel Core i7 3770K @4.4GHz
- ASUS P8Z77-V PRO
- Corsair Vengeance 2x4GB DDR3 1600MHz Low Profile (White)
- Gigabyte Radeon HD 7850 (2GB GDDR5)
- Integrated on motherboard
- 23" LG LCD/LED IPS
- 1920*1080
- Samsung EVO 128GB SSD Seagate Barracuda 2TB 7200rpm 2x500GB Seagate FreeAgent 5400rpm
- PSU
- Corsair TX650W V2 (80+ Bronze)
- Case
- NZXT Phantom 410
- Cooling
- Corsair H100 Water Cooler, 1x140mm and 1x120mm stock fans
- Microsoft Desktop 2000 Wireless Mouse
- Microsoft Desktop 2000 Wireless Keyboard
- 95 Mb/s Download 70 Mb/s Upload
