Solved Slideshow Button Not Working!
I'm using Windows Vista Home Premium x64 so maybe that's the diffrence
I've been starting slideshow just by doing 2 more clicks.
Actually I'm more intrested to fix this problem than to turn a blind eye.
Also I'm asking in other forums and if they come up with a solution I'll post it back here too.
Hey I just thought of something
The slideshow button doesn't work when the regestry is like this
But if I add a "-" to the end of the ContextMenuHanders it works
Does it mean that one of the entries there is causing the problem?
Or did adding the "-" mess up a lot more of the registry than that section only?
Going to bed for the night
4 AM here :sick:
Hey I solved the problem!
I followed this guy who had the exact same entry in his registry
Although it caused another part of his system to fail , disabling it seemed to fix the problem for both of us.
The strange non-operation of Context menu entry “Manage” on Start Menu and Desktop Icon “Computer” item. « Configuration Manager Stories and more :-)
I didn't catch it the first time cause I had to restart my computer for the disable to take effect.
In the end it was a bad Context Handler Causing the problem
CLSID {82C63EC5-1B4C-43B7-7AC8-57148B696B95}
Mine was the exact same as his laptops!
Even pointing to the same windows/assembly/GAC thingy
But I couldn't find that file anywhere on my computer so I deleted the registry string
Well, don't that beat all, same laptop issue. Glad it is sorted out for you, cause I was pretty sure we were at a step 11 on the solution priority of fixes. Thanks for posting back your solution and for using VistaForums.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
