Solved Side by Side Error
    Homebuilt
    AMD Phenom II x 4 965
    Gigabyte GA-MA770T-UD3P
    4GB DDR3
    Nvidia GeForce GTX 750 TI
    Creative Sound Blaster X-Fi Xtreme Audio
    Phillips 19"
    1280 x 1024
    1 x 128GB Samsung 840 Pro SSD 1 x 1TB Sata 1 x 160GB IDE 1 x 2Tb WD External My Book Elite 1 x 1TB WD External My Book Elite 1 x 4TB WD External My Book
    Thermaltake 850W XT
    Coolermaster Storm Sniper Black Edition
    AC-ALPINE-64PRO ARTIC COOLING
    Microflacid Sterile
    12 year old Compaq, cant see any of the letters anymore :)
    ADSL2+
    My husband and I divorced over religious differences.. He thought he was God and I didn't.
Try the Repair (not reinstall) of the .net framework again and reboot.
If that doesn't work, go to Windows Accessories and right click on Command Prompt. Select "run as administrator".
run SFC /Scannow. Does it find any errors?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Did the repair as you suggested immediately got this :-
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
ran the repair again attached is the new sfcdetails
and just in case the attachment doesn't show
https://db.tt/Sv21jPNw
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
I'm not at home this morning so I don't have time to look at the scan results.
Just to be clear, the error message you got is from when you ran the Repair option? I don't understand why it's talking about an uninstall. It shouldn't be trying to uninstall it, at least it's never done that to me when I ran the Repair.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
dunno .... but the scan results basically showed the same errors as the previous scan
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
You didn't clearly answer my question- when you click on a .net framework entry in Programs and Features you should get two options- the one I wanted you to run is the Repair option. Is that what you're clicking on which results in the installation (uninstall) problem.
In looking at the log, it appears that the .dll that WMP 11 uses to play mp3 is corrupt or you have other codec packages installed.
I'm not sure how to fix the other errors.
Are you using Vista Sp2? Do you have any problems with Windows updates?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
And yes I ended up doing the repair.
There are odd occasions when an update will fail, I read the error msg, fix and it installs.
I have the K-Lite Codec Pack installed.
My disk came with SP1, however going through the updates I cannot find KB936330, I don't know if this is relevant or not as my SP is 2, and all updates are done
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
We FINALLY get the SFC results I've been asking for since day 1! (although I'd have preferred the full CBS.log file)
Code:
2013-10-13 22:34:43, Info                  CSI    000001e2 [SR] Repairing 4 components
2013-10-13 22:34:43, Info                  CSI    000001e3 [SR] Beginning Verify and Repair transaction
2013-10-13 22:34:43, Info                  CSI    000001e4 [SR] Cannot repair member file [l:18{9}]"MSDTC.LOG" of Microsoft-Windows-COM-DTC-Runtime, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
2013-10-13 22:34:43, Info                  CSI    000001e6 [SR] Cannot repair member file [l:22{11}]"MP3DMOD.DLL" of Microsoft-Windows-MP3DMOD, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2013-10-13 22:34:43, Info                  CSI    000001e8 [SR] Cannot repair member file [l:22{11}]"MP3DMOD.DLL" of Microsoft-Windows-MP3DMOD, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2013-10-13 22:34:43, Info                  CSI    000001e9 [SR] This component was referenced by [l:160{80}]"Package_47_for_KB936330~31bf3856ad364e35~x86~~6.0.1.18000.936330-294_neutral_GDR"
2013-10-13 22:34:43, Info                  CSI    000001ec [SR] Could not reproject corrupted file [ml:520{260},l:46{23}]"\??\C:\Windows\System32"\[l:22{11}]"MP3DMOD.DLL"; source file in store is also corrupted
2013-10-13 22:34:43, Info                  CSI    000001ee [SR] Repairing corrupted file [ml:58{29},l:56{28}]"\??\C:\Windows\system32\wbem"\[l:42{21}]"Wdf01000Uninstall.mof" from store
2013-10-13 22:34:43, Info                  CSI    000001f0 [SR] Repairing corrupted file [ml:58{29},l:56{28}]"\??\C:\Windows\system32\wbem"\[l:24{12}]"Wdf01000.mof" from store
2013-10-13 22:34:43, Info                  CSI    000001f4 [SR] Repairing corrupted file [ml:58{29},l:56{28}]"\??\C:\Windows\system32\wbem"\[l:42{21}]"Wdf01000Uninstall.mof" from store
2013-10-13 22:34:43, Info                  CSI    000001f6 [SR] Repairing corrupted file [ml:58{29},l:56{28}]"\??\C:\Windows\system32\wbem"\[l:24{12}]"Wdf01000.mof" from store
2013-10-13 22:34:43, Info                  CSI    000001f9 [SR] Cannot repair member file [l:18{9}]"MSDTC.LOG" of Microsoft-Windows-COM-DTC-Runtime, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
2013-10-13 22:34:43, Info                  CSI    000001fa [SR] This component was referenced by [l:160{80}]"Package_30_for_KB936330~31bf3856ad364e35~x86~~6.0.1.18000.936330-187_neutral_GDR"
2013-10-13 22:34:43, Info                  CSI    000001fc [SR] Repair complete
There are only a couple of files which we need to fix, now..
MSDTC.LOG and MP3DMOD.DLL
I'll post a fix protocol for them later.
- are you able to access the Repair Environment ('Repair my Computer from the Advanced Boot Menu)?
    Acer Aspire 8930G
I've uploaded a file - fryaa.xip- to my SkyDrive at Noel's SkyDrive
Please download and save it.
Right-click on the saved file and select Extract all...
Change the target to C:\ and click on Extract
Close all windows (it would be a good idea to print these instructions!)
Now reboot to the Repair Environment - as soon as the machine restarts, start tapping F8 - this should bring up the Advanced Boot Menu, at the top of which should be the option 'Repair my Computer'
Pick that
You'll have to log in with your username and password.
Pick the option to use a Command Prompt
At the prompt type
DIR C:\fryaa
hit the enter key - if you get a 'Not Found' error try
DIR D:\fryaa
or
DIR E:\fryaa
The drive letter in use when you find the folder will need to be substituted (for<drive>) into the following command...
XCOPY <drive>:\fryaa <drive>:\windows\winsxs /y /i /s /v /h
(e.g. XCOPY P:\wfire P:\windows\winsxs /y /i /s /v /h )
run the command (it should take almost no time) and when the prompt returns, type
EXIT
and hit the Enter key to exit Command Prompt - reboot to Normal Mode Windows.
Now run SFC /SCANNOW in an Elevated Command Prompt
then reboot and upload the new CBS.log file to your response
    Acer Aspire 8930G
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
In your case is appears to be C: that works, so use the following command.
XCOPY C:\fryaa <drive>:\windows\winsxs /y /i /s /v /h
    Acer Aspire 8930G
Ok tried that got System Cannot Find The File Specified :cry:
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
Are you sure that you got the spaces in the right places?
(I'll replace them here with underscores __ to make it obvious)
XCOPY__C:\fryaa__<drive>:\windows\winsxs__/y__/I__/s__/v__/h
    Acer Aspire 8930G
Sorry to but in but try these commands....
  1. For where you have extracted the folder fryaa. DIR C:\fryaa
  2. For where to put the files. XCOPY C:\fryaa C:\windows\winsxs /y /I /s /v /h
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
Ok did almost the exact thing except because I am not familiar with this repair area I trued XCOPY C:\fryaa <C>:\windows\winsxs /y /I /s /v /h
With the <>. Will give yours a shot Lottie ty
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
Duh - Thanks for pointing that out, Lottie! :o - what comes of posting from work with one eye over my shoulder looking for the boss ! :p
    Acer Aspire 8930G
Ok done says it replaced two files attached and also the URL is the new sfcdetails.txt
https://db.tt/zoqRe7go
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
Great! - sorry about the confusion there :(
Please reboot twice more, then post the full CBS.log file, as I need to see the behaviour on shutdown and boot (remember you'll have to copy it to the desktop before zipping it)
    Acer Aspire 8930G
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
