'Side-by-side configuration is incorrect' message.
OK. Forget that for the moment. Any luck on uploading this file: Desktop\sxstrace.txt
Good luck!
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
I think this is it;
Code:
Begin Activation Context Generation.
Input Parameter:
 Flags = 0
 ProcessorArchitecture = x86
 CultureFallBacks = en-US;en
 ManifestPath = C:\Program Files\Samsung\Samsung New PC
Studio\NPSGuide.exe
 AssemblyDirectory = C:\Program Files\Samsung\Samsung New PC Studio\
 Application Config File =
INFO: Parsing Manifest File C:\Program Files\Samsung\Samsung New PC
Studio\NPSGuide.exe.
 INFO: Manifest Definition Identity is (null).
 INFO: Reference:
Microsoft.VC80.CRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.762"
 INFO: Reference:
Microsoft.VC80.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.762"
 INFO: Reference:
Microsoft.Windows.Common-Controls,language="*",processorArchitecture="x86",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.0.0"
INFO: Resolving reference
Microsoft.VC80.CRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.762".
 INFO: Resolving reference for ProcessorArchitecture x86.
  INFO: Resolving reference for culture Neutral.
   INFO: Applying Binding Policy.
    INFO: Find publisher policy at
C:\Windows\WinSxS\manifests\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_516e2e610f48bda6.manifest
    INFO: Publisher Policy redirected assembly version.
    INFO: Post policy assembly identity is
Microsoft.VC80.CRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.4053".
   INFO: Begin assembly probing.
    INFO: Attempt to probe manifest at
C:\Windows\WinSxS\manifests\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442a985d.manifest.
    INFO: Manifest found at
   INFO: End assembly probing.
Microsoft.VC80.CRT.mui,language="*",processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.4053".
  INFO: Resolving reference for culture en-US.
    INFO: No publisher policy found.
    INFO: No binding policy redirect found.
    INFO: Did not find the assembly in WinSxS.
C:\Windows\assembly\GAC_32\Microsoft.VC80.CRT.mui\8.0.50727.4053_en-US_1fc8b3b9a1e18e3b\Microsoft.VC80.CRT.mui.DLL.
    INFO: Did not find manifest for culture en-US.
  INFO: Resolving reference for culture en.
C:\Windows\assembly\GAC_32\Microsoft.VC80.CRT.mui\8.0.50727.4053_en_1fc8b3b9a1e18e3b\Microsoft.VC80.CRT.mui.DLL.
    INFO: Did not find manifest for culture en.
Microsoft.VC80.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.762".
C:\Windows\WinSxS\manifests\x86_policy.8.0.microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_49ef489714173a89.manifest
Microsoft.VC80.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.4053".
C:\Windows\assembly\GAC_32\Microsoft.VC80.MFC\8.0.50727.4053__1fc8b3b9a1e18e3b\Microsoft.VC80.MFC.DLL.
    INFO: Attempt to probe manifest at C:\Program Files\Samsung\Samsung New
PC Studio\Microsoft.VC80.MFC.DLL.
PC Studio\Microsoft.VC80.MFC.MANIFEST.
PC Studio\Microsoft.VC80.MFC\Microsoft.VC80.MFC.DLL.
PC Studio\Microsoft.VC80.MFC\Microsoft.VC80.MFC.MANIFEST.
    INFO: Did not find manifest for culture Neutral.
 ERROR: Cannot resolve reference
ERROR: Activation Context generation failed.
End Activation Context Generation.
Input Parameter:
 Flags = 0
 ManifestPath = C:\Program Files\AVG\AVG9\avgtray.exe
 AssemblyDirectory = C:\Program Files\AVG\AVG9\
INFO: Parsing Manifest File C:\Program Files\AVG\AVG9\avgtray.exe.
 INFO: Reference:
 INFO: Reference:
 INFO: Reference:
Files\AVG\AVG9\Microsoft.VC80.MFC.DLL.
Files\AVG\AVG9\Microsoft.VC80.MFC.MANIFEST.
Files\AVG\AVG9\Microsoft.VC80.MFC\Microsoft.VC80.MFC.DLL.
Files\AVG\AVG9\Microsoft.VC80.MFC\Microsoft.VC80.MFC.MANIFEST.
Input Parameter:
 Flags = 0
Studio\NPSGuide.exe
 INFO: Reference:
 INFO: Reference:
 INFO: Reference:
:D
Hello!
I know this is really frustrating. I am sorry for the delay. I am trying to answer everything as quickly as I can, but I do have a life outside of these forums, and very many people to help.
I think that we will have one last try, and after that possibly consider a reinstall.
Can you please have one more try at this, because this is the log I need.
Please download VEW by Vino Rosso http://images.malwareremoval.com/vino/VEW.exe from here and save it to your Desktop.
Double click it to start it. Note: If running Windows Vista or Windows 7 you will need to right click the file and select Run as administrator and click Continue or Allow at the User Account Control Prompt.
Click the check boxes next to Application and System located under Select log to query on the upper left
Under Select type to list on the right click the boxes next to Critical, Error and Warning and Information.
Under Number or date of events select Number of events and type 20 in the box next to 1 to 20 and click Run
Summary: Check all six check boxes, choose a number of reports, and set it to 20.
Once it finishes it will display a log file in notepad. Ideally, upload it, but pasting it between CODE tags is also fine.
Try running it, and saving it, and hopefully, eventually, one of them will open up!
The very best of luck,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Nope, it still won't save or run I'm afraid. :( I've tried many many times, and after every save/run I've searched my whole computer for the file after and it can't be found. My computer just doesn't want to save it for some reason. It may be a protection thing? I have practically no idea.
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Unfortunately that file does the same too! :S
Then unfortunately, I don't think that this machine is repairable. What is the make and model of this computer?
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
