Sharp drops in fps
Tried changing resolution did not work, and it also takes about 10 minutes to change resolution considering the fps...
    Hp Pavilion a1730n
    4600+ AMD Athlon 64 X2 Dual Core Processor
    2048MB
    Nvidia GeForce 6150 LE
Have you tried doing a system restore to before the problem started? This would indicate whether the problem is software or hardware
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
u5 if you got nivida like me and got the new nvida settings thing in the tool bar botten right change the "adjust display settings move it all the way to left or performces it seems to work for me but only tried it with one game
it seemed to work for awhile now it doesnt
