sfc performed how to find results?
Looks like you are good. Do you encounter any specific problems ?? If yes, we'll have to revisit.
    Dell
    Q6600
    HP w2207h
i have done this sfc scan on my desktop and my fathers laptop. "sorry for any confusion"
on the desktop just the 1 issue sound related. i think it may be to do with codec (i have 2 sound outputs headphone jack and hdmi... headphone jack plays windows sounds beeps bing bongs etc and video or music tracks etc. however hdmi will only play windows sounds when either on you tube or windows media player is open?)
as for laptop
the issue was with freezes after windows restarted after configuring windows .net framework 4 updates. and as far as i know that has not happened yet but have not had any windows updates since applying fixes. so have not been able to test..
if you require any more details or info to assist a diagnosis just ask and i will try to provide anything you need..
thanks
    acer aspire revo
    intel atom 230
    2gb
    integrated nvidia ion
    lenovo n5901
    lenovo n5901
To show the cbs log type this into cmd window and it will open in notepad.
notepad C:\windows\logs\cbs\cbs.log
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
thankyou i will give that a go
thanks for helping
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
And if you want to do a bit a data reduction down to the essentials, use this command:
findstr /c:"[SR]" %windir%\logs\cbs\cbs.log
    Dell
    Q6600
    HP w2207h
sorry whs to request repeat but what does that do?
thanks
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
thanks
The notepad C:\windows\logs\cbs\cbs.log command works but it gives you a gezillion pages of information.
The command I posted reduces the data significantly to what you need to see. It shows it in cmd. There you right click on it and click Select All. Then you right click on the highlighted text and you can paste it into a Notepad or Wordpad or Word.
    Dell
    Q6600
    HP w2207h
AHa! brilliant that sounds much better than going through loads of pages that i wont even understand looking for something. (needle in a heystack)
thanks for the tip
much apreciated.
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
You are welcome.
    Dell
    Q6600
    HP w2207h
