selecting the best fans and heatsinks
Nope do not have much idea on that.
Actually i think only Prime ABGB(based in lamington road,Mumbai) imports Thermalright products.So check their website if they have that HSF.
    Intel
    Nvidia 9650M GT
    Asus N80VN-X1 Laptop
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
i have an E2180 which is a relatively cool chip to begin with, but i swapped out the stock heatsink/fan for a thermaltake big typhoon vx. somewhat of a handsome frog to install because of it's massive size, but my cpu's been running at 20C at idle. i have done any stress tests yet, so i'm not sure what itd do for any load temps, but i'm guessing it wont be too high.
    Intel E2180 @ 3.0Ghz
    Gigabyte P35-DS3-L
    Patriot Extreme Performance 2GB 4-4-4-12
    EVGA 8800GT
    750 GB -Western Digital Caviar SE16 WD7500AAKS 1 TB - Western Digital MyBook
20c idle sounds like your temperature readings are a bit off. Unless your ambient is around 10-12c which is quite cool.
well i was getting the temp readings from the BIOS and also from everest.
    Gigabyte P35-DS3-L
    EVGA 8800GT
What is your normal ambient temperature? Only thing you should know is that CPU core temps can not be lower than ambient unless you are using some very extreme cooling solutions. With a heatsink/fan, it's impossible. So, measure the air in and around your case and go from there :)
Typical delta from ambient to idle core temp should be somewhere around +15-20c depending on the type of cooler you've picked. My cores idle at 38-40, and my ambient is 21c or 70F +/- 2F. That's with a Thermalright Ultra 120 and AS5. However, I'm pumping 1.425 volts into my chip, so it's approaching it's thermal limit with air cooling.
Your chip should definitely run cooler than mine, but not that much cooler :)
Well this is what Everest is telling me, the temps are a bit higher cause i was just running some apps:
Motherboard: 34 C
CPU: 25 C
GPU: 53 C
HDD: 35 C
my core voltage is at 1.39V
    Gigabyte P35-DS3-L
    EVGA 8800GT
Motherboard: 34 C
CPU: 25 C
GPU: 53 C
HDD: 35 C
If it is the same trunion as speedfan (85) you need to add 15c to it. Right now speed fan reads cpu: 23c, core 1: 20c, core 2: 20c. In actuality the temps are 38c, 35c and 35c.
    i7 940 @ 4GHz (193 x 21) w/CNPS9900LED
    Asus P6T Deluxe (BIOS 1604)
    6GB (3x2GB) Corsair DDR3-1600 @ 8-8-8-21-1N
    Tri-Fire 4870x2 + 4870 1GB
    Azun Prelude 7.1 + Inspire T6200 5.1
    Dell 3008WFP
    2560 x 1600
    300GB WD VelicoRaptor
    SilverStone DA 1200
    CM HAF 932
    3x230mm 1x140mm 1x120mm
    MX Revolution
    G15 Gaming KB
well im running everest ultimate 4.20 beta, according to things ive read, they corrected the temp readings for this beta...
    Gigabyte P35-DS3-L
    EVGA 8800GT
Yes patio you CPU Temp can never be below the Ambient/Room Temperature.
Your temps seem good but you must be living in a really cold area for the temps to be spot on !
    Intel
    Nvidia 9650M GT
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
