screen saver
Mine dosn't say Pictures it says Windows Photo Gallery
When you bring up the Screen Saver window then click on the Settings button you should have this window come up, tell us if you do.
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
When I put my screensaver on photo gallery it doesn't give me the option of shutting down. It just keeps going and then when I go to use it again, it takes quite a while for the screen to come back up. I have Vista. I also have a folder called pictures that has about 20 pictures and it works fine with that, but not the photo gallery. Can you help?
I didn't mean shutting down, just going black again and then when I touch the key it starts up again, that is what xp used to do. I am sure at this point it has something to do between the amount of pictures of gallery vs. pictures
Can you please keep this all in the same thread PattiChati or else things will get very confusing for everyone.
I've asked you a question in the original thread which you haven't answered yet so if you still want help will you please go back to that thread and stay there ;)
    Windows 10 Home
Post merged to this one. ;)
I am sorry, I didn't know I switched forums. Maybe I hit post reply or quick reply and one of them was wrong. Let's hope this one isn't. Mine is exactly like that. Except I have a check in "shuffle".
So you have it set to show pictures from your Pictures folder then, as I have but I don't have the Shuffle button checked.
Do you have all your photo's stored in that folder ?
The photo's in the Photo Gallery should be the same ones that are in your Pictures folder so that shouldn't make a difference with the way the Screen Saver works.
How much time do you have set before the Screen Saver comes into play ?
PS: Thanks Shawn for merging the threads makes things a lot easier when it's all in one place.;)
    Windows 10 Home
Still not sure why your's wont work, but these are the windows that come up for me when setting the Screen Saver.
When you right an empty space on your desktop you then click on Personalize at the bottom of the window, then click on Screen Saver in the list on the next window and it brings up this one.
Then when clicking on the settings button it brings up this one.
Let me know if your's are any different, can't stop any longer but I'll be back later.
    Windows 10 Home
Another thoughts just come to me, have you had a look through the help when pressing the button at the bottom of the second picture, How do I customise my screen saver?
Because we don't know what machine you have, you haven't filled out your System Specs, we don't know if your machine is capable of running with some of the themes.
    Windows 10 Home
