You should upgrade or use an
alternative browser .
Sata/Ide to usb hardrive not recognised
Please help.
I have just bought a Sata/Ide to usb converter, but when I plug my harddrive into the usb port of any computer (vista or xp) it beeps and installs the Drivers and even adds the little safely remove hardware icon down in the system tray. but I can't find the hardrive in my computer or in administrative tools. I have tried an IDE hardrive,a 2.5 inch sata hardrive and a cdrom drive, why is it not working.The Adapter is Brand New, I have only just opened it.
Toshiba Satellite Pro l300
Intel(R) Celeron(R) CPU 550 @ 2.00GHz
Intel Corp. 88395664Q
DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
Realtek HD Audio
Matte screen
1024 x 768 x 4294967296 colors
120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
Notebook
Fan cooled
Logitech Cordless Optical
Logitech Cordless Desktop EX110
256Kbps
I like Spore,Rabbits and I'm a Computer Freak.
Check for it in Device Manager?
I remember my friend had one of those and had to return it for the same reason.
-Book
under device management it shows up as "USB DEVICE"
Realtek HD Audio
Matte screen
Notebook
Fan cooled
256Kbps
Disable and re-enable it through properties see if that works.
-Ryu
I got the IDE hardrive going. when i plug in my sata hardrive "My Computer" Freezes every single time and it doesnt show up in device manager at all. Is there a way to see if my hardrive is corrupt, if not , how could i format my hardrive then retrieve all of my data afterwards
Realtek HD Audio
Matte screen
Notebook
Fan cooled
256Kbps
Does it show up in Disk Management ? ?
If you format it BEFORE backing up your data will be gone.
Intel Q6600
ASUS P5K MBoard.
4G OCZ PC2 8500 Platinum
EVGA 8800GTS Vid Card
500G Seagate SATA
200G Seagate SATA
100G WD Caviar SATA
80G WD Caviar IDE
OCZ Elite 800W PSU
RaidMax Smilodon Case
Lite-On dual layer DVD burner X 2
Dos 6.2;Win2K;XP; &
Vista Ultimate 64Bit.
Realtek HD Audio
Matte screen
Notebook
Fan cooled
256Kbps
