Safari 4 Beta has arrived
On the left hand side it should show your favs from Firefox. I know mine does and it also showed IE favs as well.
yes it does but it did not import anything
cheers brad
    PHENOM II X4 Quad Core 965 Black Edition CPU, 3.40 GHz
    GA-MA790FXT-UD5P
    G.Skill 4GB (2x XMS3 2GB) PC-12800 (1600MHz
    nvidia 9500 gt
    on board
    T231H / X243H ACER
    1980x1050
    Hitachi 500 samsung 1terabyte wd 750
    550 watt
    cooler master
    stock
    logitech
    microsoft
    8000 dl 356 ul
    booting xp32 2x dual pci-e digital tv tuners xp pro v 1xpci digital tv tuners vista ultimate 64 1x pci sat tuner win7 64 win8 64
cheers brad
Go to the book icon in the upper left hand corner. This should bring your favs. Go to each site and bring them up. Then press add to favs. It worked for me.
    Cyberpower
    AMD Phenom X4 9850
    MSI K9N SLI V2
    8 GIG DDR 800
    EVGA 9800 GT 512mb
    onboard
    SyncMaster 220wm
    Hitachi something or other 500 gigs
    650 watts
    GA-MA790FXT-UD5P
    nvidia 9500 gt
    on board
    T231H / X243H ACER
    1980x1050
    550 watt
    cooler master
    stock
    logitech
    microsoft
    8000 dl 356 ul
Or click the Gear icon and choose "Show Menu Bar"
Now you can use the available "File"menu to import an html file.
I exported my Google Chrome bookmarks to an html file and used that. Worked fine.
    HP 9203tx
thanks that got it.
i like it accept that it doesn't reopen all tabs from last session when started .
hopefully they will add that option in the near future.
i know theirs an option to open all windows from last session but that actually starts a whole new window from the one just started instead of just opening the tabs in the current window
cheers brad
    GA-MA790FXT-UD5P
    nvidia 9500 gt
    on board
    T231H / X243H ACER
    1980x1050
    550 watt
    cooler master
    stock
    logitech
    microsoft
    8000 dl 356 ul
I've been absolutely thrilled with Safari 4 Beta :). So good, so fast and never crashed once. My only regressions are:
1. bookmarks can't be arranged in any way (by name, by date..) which kind of sux;
2. I would prefer to have "new tab" button on the left side (where back/next buttons are) instead of far right tab position.
3. Also I would like to see more zoom control options in the final version (like 100%, 110%,120%) you know, user defined steps and also to have ability to set up default zoom.
4. tab preview (when you hover mouse over tabs)
And yes, there is no Full Screen view in this beta build (at least in Vista).
Cheers,
Miki
    Sony Vaio Z590
    Intel Core 2 Duo P9500 2.53GHz
    4GB DDR3-1066Mhz
    Nvidia 9300M GS and Intel X4500M HD
    1600x900
    Toshiba MK3252GSX 320GB (5400 rpm)
Yes, I noticed you can not move your favorites list around to what you want. Maybe they will look into this for the final.
    Cyberpower
    AMD Phenom X4 9850
    MSI K9N SLI V2
    8 GIG DDR 800
    EVGA 9800 GT 512mb
    onboard
    SyncMaster 220wm
    650 watts
Nah. Gone back to Firefox. Much more fun. Much more mine. J:)
    custom build
    Q6600 OCd to 3.06GHz
    Asus P5Q Pro
    Corsair 2x2GB TWIN2X4096-8500C5DF G
    XFX GTX 260 Black Edition
    Dell Utrasharp 2408WFP
    1920x1200
    2x Samsung Spinpoint 500GB 1x Samsung F1 1TB
    Thermaltake Toughpower 650 watt
    Coolermaster Cosmos S
    Tuniq Tower 120 + 3x120mm + 200m side fan
    Roccat Kone
    logitech Wave
    supposedly 8mbps actually about 4 or 5
    love this mouse
FF has much better bookmarks manipulation options, even from Bookmarks menu have various options for rearrange/rename etc. Also I miss some of the FF extensions, but I can live with this. Just hope Safari will either offer some heavy customizations or allow extensions which would be great for FF users.
I have never used Safari 3 though, as it had this "blurry font issue" on Windows. I'm glad this has changed in Safari 4.
Also, I hope in final version we'll have more options in Downloads, at least double click to open downloaded contents as oppose to clicking that small icon on the right.
It may sound funny, but I would really like to see quick search (when you press "/" in FF or Opera) instead of "old-style" CTRL+F.
Cheers,
Miki
    Sony Vaio Z590
    4GB DDR3-1066Mhz
    1600x900
