Blaydrnnr, again on the thing you siad about your case being warm.. How's your cable management? Can you maybe post a pic of your rig with side panel off (not just to see the cable management, jus want to see it on the inside act, such nice config (or at least compared to mine..
)). Also, where do you put your case? Has it got enough room to breathe or is it like crammed into a drawer of your desk?
Cheers, good luck on the OC-ing (You know what, I'm gonna start OC-ing with you! or at least my CPU, for the card I don't even bother. It's more fun to do with two of us, right:D)
Amplid
)). Also, where do you put your case? Has it got enough room to breathe or is it like crammed into a drawer of your desk?Cheers, good luck on the OC-ing (You know what, I'm gonna start OC-ing with you! or at least my CPU, for the card I don't even bother. It's more fun to do with two of us, right:D)
Amplid
- Intel Q9550 @ 3.2 GHz (for now)
- Asus ROG Striker 2 Extreme
- 2 x 2Gb Patriot DDR3
- XFX GeForce 9800 GTX+
- Creative Supreme FX 2
- Neovo F417 17''
- 1280x1024
- Samsung SP2504C SATA 7200rpm
- PSU
- Pc Power & Cooling 750
- Case
- Coolermaster CM 690
- Cooling
- 6 120mm's, Xigmatek HDT 1283 with crossbow backplate
- Logitech Cordless Trackman Wheel
- Logitech G11
- ~1000 Kb/sec
) heats the room nice in winter...
but this Vista system doesnt run very hot right now, its just a closed case, with three stock fans.... not a bad air movement for a stock case for OEM.. but with a new card coming soon, ( 4870x2 ) and I already swapped the PSU to a 1000W, so a stock cooler on this card is just going to be alittle warm.. but with Riva Tuner running it at 80%, I havent seen it above 62C in some long hard gaming in CoD4 and Quake4 or Crysis yet.. thats not too bad right now for a card under load...but along with the new card, I went for a Tuniq tower for the PSU and I'll just have to see what they will come up with for a GPU cooler for that new card.. things should be OK for awhile...unless I can figure out how hard it would be to swap my CPU for something.. " HOTTER"???
) I dont mind paying.. just wasnt sure for just stability testing if a freebie would do just as good. Stock clocks are 600/900/1500.. I know it can do better then that....but since I dont have access to the BIOS for voltage and timings.. there is only going to be so much I can do...but.. anything I can get to help in gaming and rendering would be nice!!:D If not.. no loss, it does OK, and the newcard will be a whole new ball of wax.
