Repair Install For Vista
How To Perform a Repair Installation For Vista
This will allow you to repair your Vista installation and keep all of your personal user account files, settings, and programs. You will be performing a Upgrade Install from within your currently running Vista.
You will have to use the exact same Vista installation media type that you currently have installed.
  • You will not be able to do a upgrade install in Safe Mode.
  • You must have Retail Full or Upgrade Vista installation DVD to do this. Some people have had problems with a Full version letting them do a upgrade install though.
  • A OEM (retail version) Vista installation DVD that you buy at a store and does not come with the computer are usually the same as a regular retail (full or upgrade) Vista installation DVD, but have a OEM license (product key number) instead of a retail license (product key number).
  • If you have a OEM Recovery Vista installation DVD that came preinstalled with your OEM brand computer instead, then it will most likely only be a clone of the hard drive with Vista allowing you to only do a clean install with it instead. These OEM computers often have a Recovery D:\ partition that does the same thing as the OEM Recovery Vista installation DVD.
  • If you have a Anytime Upgrade Vista installation DVD, then you will not be able to do this.
  • The Vista installation DVD that you use to do the repair (upgrade) install must be the same or newer version of Vista with the Windows Updates and SP level than what you currently have installed. If the DVD is a older version, then you cannot do a repair (upgrade) install with it.
  • IF YOU HAVE THE VISTA SP1 INSTALLED:
    • This will not work if you have SP1 installed unless your Vista installation DVD includes the SP1, or you create a Vista SP1 slipstream installation DVD (See below). When the SP1 is installed, it will give Vista a newer version number than what is on the original Vista installation DVD.
    • You can only do a Upgrade install if the currently installed Vista is the same or older version than what is on the Vista installation DVD.
    • To create a Vista SP1 slipstream installation DVD to use to do a Repair (upgrade) install, see: How to Create a Vista SP1 Slipstream Installation DVD. Note that this does not always work to use for a Repair install.
    • Another option is to uninstall the Vista SP1, then run the Repair install and install the SP1 again afterwards. To uninstall the SP1, see: Microsoft Help and Support: How to uninstall Windows Vista SP1 as a troubleshooting step
  • IF YOU HAVE THE VISTA SP2 INSTALLED:
    • This will not work if you have SP1 and SP2 installed unless your Vista installation DVD includes SP2.
    • To create a Vista SP2 slipstream installation DVD to use to do a Repair (upgrade) install, see: How to Slipstream Vista SP2. Note that this does not always work to use for a Repair install.
  • Be sure to backup any important data you have, just in case something goes wrong during installation. You may need to reinstall some of your drivers. You do not want to do this if you are dual booting with XP and Vista was not installed as the primary boot drive. It can cause XP to not startup anymore.
If you are have installation error problems, then see:
If you changed the default location of the Program Files or Programs Files (x86) folder, then you will need to change it back to the C: drive, and change any shortcuts that pointed to the other location to also point to the C: drive before doing a repair install.
ITEMS THAT WILL BE RESET TO DEFAULT:
  • If Vista is still not working properly afterwards, then a Clean Install would be recommended.
  • You may need to reinstall some of your drivers after the Repair (upgrade) install.
1. While logged in Vista as an administrator, insert the Vista installation DVD into the DVD drive, or connect a Vista installation USB thumb/key drive.
WARNING: Do not boot the computer and run the Vista installation DVD from boot. A upgrade install will not work this way.
If you do not have a Vista with SP1 installation DVD/USB, then you can download an official Vista with SP1 ISO file here: Microsoft: Vista Direct Download Links, and use Windows 7 USB-DVD Download Tool to create a bootable DVD or USB flash drive with the ISO to do the repair install.
2. Click on Install Now to start the upgrade. (See screenshot below)
NOTE: If AutoPlay does not load the Vista setup screen, then open your DVD drive in Computer and click on the Setup file.
3. If you want Vista to check for updates during the installation, then click on that to select it. (See screenshot below)
NOTE: It will install faster if you select Do not get the latest updates for installation. You can install them later through Windows Update.
4. Do not type in a product key. (See screenshot below)
WARNING: If you do type in the same activated product key that you already have installed, then you can end up in Reduced Functionality Mode.
5. Leave the Automatically activate Windows when I'm online box unchecked.
6. Click on Next.
7. Click on the No button for the Do you want to enter your product key now? prompt. (See screenshot below)
8. Select which edition of Vista you have. (See screenshot below)
9. Check the I have selected the edition of Windows that I purchased box and click on Next. (See screenshot below)
10. Click on the Upgrade option. (See screenshot below)
11. Follow any instructions left until Vista is through installing and has rebooted to the final welcome screen on the Vista desktop.
12. Remove the Vista installation DVD.
13. Check to see if any files are missing. If so look in the bolded files shown in step 14 below to see if they are in there. You can then just copy them back.
14. Run Disk Cleanup.
A) If listed, check Files discarded by Windows upgrade. (See screenshot below)​
NOTE: These will be the leftover upgrade files, C:\Windows.old, C:\$INPLACE.~TR and C:\$WINDOWS.~Q, that did not get copied over. If any personal username files are missing, it would be in these folders.​
B) Click on OK to delete it.​
15. Now all you need to do is to activate Vista.
A) Right click on Computer (Start Menu) and click on Properties, or open the Control Panel (Classic View) and click on the System icon.​
B) Scroll down a bit and click on: Activate Windows Now. (See screenshot below)​
If it's freezing that bad, then yeah I would try the other forum location here first to see if we may be able to solve the crashing issue.
You would usually be able to download device drivers for your 32-bit Vista at each device manufacturer's website in it's support/download area.
Thanks again for your answer.
I have consulted the Crash-forum and found instructions for what to do in case of
freezes, but the freeze happen so quickly today that it is not possible to do anything. I write this email from another Pc.
I have read somewhere that it is possible to do a clean full install without destroying the existing user data, by simply not formatting the disk!
Is that true? Would be nice!
Guy
    Medion P7300 D
    Core 2 Quad E8200
    MSI Intel-P35
    4 GByte RAM
    MSI Geforce-9600GT
    ACER LCD
    Western-Digita
You could do a custom install at boot. It's like a clean install, but places your current installation in the C:\Windows.old folder during the new installation. After the installation is complete, you can copy the files that you want from within the C:\Windows.old folder back into the new installation. You will still have to reinstall all of your programs and drivers though.
http://www.vistax64.com/tutorials/241565-custom-install-vista.html
I have read now your tutorial about the Custom installation and also the restore/delete of the Windows.old folder.
Congratulations on your very well done site!
I think I have understood, but to be absolutly sure : This Windows.old folder contains not only Windows SYSTEM folder files (like c:\windows) but also ALL USER files and application data. Is that true?
Does it contain EVERYTHING that was on c:\ before the new install ?
Guy
    Medion P7300 D
    Core 2 Quad E8200
    MSI Intel-P35
    4 GByte RAM
    MSI Geforce-9600GT
    ACER LCD
    Western-Digita
Guy,
Yep, you have understood. It will contain everything on the C: drive. :)
Guy,
Ok, thanks. That's fine then!
I had some doubts because in the "Custom Install Vista" tutorial when you choose CUSTOM (on point 9) it is said "This option does not keep your files, settings and programs" .
In the "How to restore your windows.old" they use a complicated procedure with the command prompt to restore the files.
I understand that one must reinstall the application programs, but is it not
possible to use simply the normal windows file explorer's copy function to recuperate the user application data and files from the windows.old folder?
Guy
    Medion P7300 D
    Core 2 Quad E8200
    MSI Intel-P35
    4 GByte RAM
    MSI Geforce-9600GT
    ACER LCD
    Western-Digita
Guy,
"This option does not keep your files, settings and programs" message just means that it will not keep them in the new installation afterwards, but they will be in the C:\Windows.old folder though.
You could add this to your context menu to help make it a bit easier to copy those files back from within the C:\Windows.old folder to the same location in the new installation.
http://www.vistax64.com/tutorials/89196-context-menu-add-copy-folder-move-folder.html
I'm wondering whether or not to do a repair install in my main Vista Ultimate SP2 x64 boot or simply format and reinstall that partition.
This is all because I cannot, no matter what I try (read a zillion tute's, disabled all protection etc. etc.), update my Nvidia GTX295 graphics drivers above the very basic that Windows installs in Safe Mode after a driver uninstallation - 182.15 which is way below what Windows usually starts with when the system is installed. (Posted in the appropriate thread both here and at Nvidia forums, no suggestions forthcoming thus far).
The other Vista on D: and my 2 Win 7 SP1's are all at 266.58 which is the latest WHQL per their website. Their CP's all show DX11 being used at least in part. I'm aware that DX11 didn't really come into its own until the 3xx card series and above. However the CP in this boot shows DX10 and I have a feeling that has something to do with it in that the installer is looking for something it can't find - it takes forever to complete. That could be of course because this driver is 2 years old +.
I have run the DirectX installer from MS website and am slap-bang up to date. Nothing is malfunctioning otherwise as far as I know. DxDiag concurs DX11 is alive and well.
It's such a shame if I have to format and reinstall but may have to if you think a repair install probably wont achieve anything.
Verdict anyone?
:cry:
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Hello Peter,
I'm not sure if a repair install will help or not since the same driver will most likely be carried over into the repaired (in-place upgrade) installation.
Have you already tried manually uninstalling the "Display Adapter" driver for you card in Device Manager with the option to delete the driver file checked? If it works, you may be able to install the new driver version normally.
Hi Shawn and thanks for coming to my rescue once again. I try my best to help people when I can but this one has foxed me I'm afraid.
Tried all that and even ran Driver Sweeper as per Nvidia Forum's Tute: GeForce Driver Installation Guide - NVIDIA Forums - about 30 times now.
I did at one time have a more recent driver installed but all these aborted attempts wiped out that restore point eventually. (Windows installs initially in a fresh install a higher driver version in the 200's range).
I couldn't roll back because Driver Sweeper got rid of them anyway.
Always fails to install PhysX, 3D Vision and Control Panel.
I think you are right as a repair install, and I've done plenty of those, probably would just accept the installed driver as it isn't a system driver.
Oh well, not starting that this evening. Will think about a format/install tomorrow...maybe! :confused:
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Hope it goes well. :(
We shall see. I have so much installed on this OS, iTunes with all my iPad apps is going to be a particularly messy p.i.a I am sure.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
OK I managed to avoid a complete format and reinstallation of Windows.
I had overlooked that I had increased ICH and IOH voltages by 0.1v each, which seems insignificant but I guess Nvidia's installer balked at an increased PCIe voltage. I had done that ages ago on advice from a fellow grid-computing person and forgotten all about it. Once I set the BIOS to default values the installer was happier.
Not altogether happy though. The latest WHQL drivers 266.58 installed OK but failed to start, code 43, which could be just about anything.
Did the cleanup routine again and tried 260.89 and that is where I achieved success finally.
I can now breathe easier. I would still love to know why Nvidia makes our lives so difficult though.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
That's great news Peter. :)
Thanks. ;-)
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Thanks a lot Brink.!
Finally I solved my problem with error code: "0x80070246"
Thank you brink, you really helped me!
:D
    Gateway mx6947m
    500gb
You're most welcome NSgsus, and welcome to Vista Forums. I'm happy to hear that you got it sorted. :)
Hi
I've just registered to say thank you very much for your help and your great guide, because of you I have fixed my Vista Home Premium x32 installation and my computer is working great again.
I had the issue where my computer would not boot up, this appeared to happen after some sort of update, but the computer just could not load Vista, it only got as far as the black screen, it just recycled the power before the Vista orb had even appeared.
I could not start in Safe Mode and when I used the system repair utility all I got was the: Problem Signature 09: WrpRepair error. All of the advice on the Internet was either completely wrong or wipe your hard disk and do a full re-installation. Arrghhhhh!
It was so frustrating until I found this guide and followed your instructions TO THE LETTER. And I'm delighted because the upgrade Vista option allowed me to keep everything, all my settings, the look and feel, everything! So it has saved me an awful lot of heartache.
I think that you should thank people that help you and use the opportunity to say that this solution worked for me and should work for you if you have the same problem as long as you back up your data first and follow the instructions exactly.
Vista corrupts too easily!
Sorry I should mention that in order to follow this guide you have to get into Vista, I achieved this by running a system restore from Vista's Recovery options (using F8) and going back to a time when I knew the computer worked.
The first time I tried to do the upgrade reinstallation it would not let me go any further until I had removed Powershell, which I did using the Remove Windows Features in the Programs and Features section of the control panel. I removed both Powershell options with no bother, I did not reboot, because it wouldn't have come back up again and then I rang the Vista SP2 DVD installation and it all went perfectly.
The only issue was the nVidia driver which had become uninstalled but was easily reinstalled when I did the 96 microsoft updates.
Be warned the reinstallation takes a long time as does the 96 updates, but it was worth not to have to start from scratch.
Thanks again!
Alan
You're welcome Alan, and welcome to Vista Forums. I'm happy to hear that you got it sorted. :)
Hello Brink...in regards to your tutorial and
"ITEMS THAT WILL BE RESET TO DEFAULT:
...is there some type of .ini or .sys file or registry entry that these (Vista Services/Visual Efects/Device Drivers) settings are stored in? In other words, could I just backup a copy of my settings, then copy/restore them when I do the Repair Install? Is there an easy way of doing this, or do I have to reapply these settings/install the device drivers one-by-one?
Will everything else (files/desktop image/shortcuts/installed programs/network settings/printers) be in tact and un-molested?
Hello Tresean,
It's basically anything that is not stored in a C:\Users\(user-name) folder has a good chance of being reset to default.
You can see how to create a REG file in the TIP box at the Services link for them.
Drivers will just have to be reinstalled if any of them get reset.
You could export the Schemes key in METHOD TWO at the Computer Sound Event Schemelink to save them to a REG file.
