Reinstalling Vista w/o using recovery disks?
Thanks man. You've been a great help. I also got some good advice on sevenforums which i think is affiliated with this site, not sure.
So I need to do that to boot from the USB then? Maybe it will be easier to just burn a DVD then.
LOL Im there, too. Its affiliated with Vista.
Personally, I like the DVD, been there and done that; never used the usb.
I think that all you need, unless there are unforseen problems, is the tutorial that I gave you earlier.
The main thing is that its a clean install (format) and you have a product key number.
Not had a proper chance to look at this yet. Trying to make the best of the nice weather before the storm. Anyway I went into setup mode by pressing F2 and it's asking for a password!!! A password? Why do I need a password? I tried the admin account password but it didn't work.
Anyone know where I can find this password or a way to circumvent it? Hope this doesn't mean I have to use the recovery disks instead now...
Just put the CD in and see if it boots
Not booting from the disk automatically. I have boot.wim install.wim and X14-63452. Should I double click on boot.wim or install.wim from explorer then.
I getting hounded by updates while I do this :-(
Try clicking on boot.
The request for password is coming from your computer. Try to put nothing in and continue.
Try word, password
If you have a password for you modem, try that too.
Make and model of computer, please
