Registry repair?
Do the above sites scan and then make you pay to remove or repair them?
I lost a game I had downloaded the other day from Game Giveaway of the Day site.
I also lost my Advanced System Care than scans for problems. Everything else seems to be "oK"
they are free. and will hopefully repair any damage if it exists.
the viral scan is NOD32 and will scan/clean free
the others are Windows built in utilities.
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
Ps- Advanced Systemcare has a registry cleaner. This may have caused corruption that would have led to the issues you were having. The restore would have "undone" any registry damage. I would think twice about re-installing this program, and Instead go with either Avira or Avast. both are free, and you also have Windows Defender antimalware.
to scan with Defender:
start>in search, type defender>click program
at top, click arrow next to "scan" and do a full scan
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
Did you perform a system file scan and the disk check I linked you to?
You also need to run "windows Update" you are a month behind on security updates, and new updates were released today.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
