Redirecting won't stop
OK
so you click on the shortcut and gmail launches. what does it look like? snip please?
thanks
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
here is where you change users to your current set up.
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
mram, does this problem occur if you use firefox?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
it only happens on the one user, but thats the user w/all of my docs, and it would be a major pain to move them. This users email is fine as you see (it works) .
I am not at all familiar w/firefox, I don't know anyone that is using it and I' never seen or looked into it but I'm open minded about it.
    dell
mram
You can have both on the same machine. SO if you want you can try firefox without having to give up IE. Im a firefox fan, there are lots of things you can do with it that IE cant
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
how do you use both ? I never heard of or did "snipping" 'till an hour ago, If I can switch back, ok what are the advantages of firefox or differences
    dell
Ken, thanks for your help anyway. I think that I will try firefox tomarrow, just read about it and am impressed. It can't hurt and mightjust be the solution to my problem. Thanks again.
Mickey
    dell
mickey
any time sorry I couldnt get IE working. If you need help with FF let me know
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Ken, Firefox fixed my email problem. I like it, but its still kind of alien. I have one problem that I can't seem to find an answer for. When forwarding an email is there any way to cut or erase the addresses that were on the message sent to you. You could do that w/IE7. I forward messages to people that I don" want to know where THE MESSAGE CAME FROM, other than from me. I added "cut, copy,and paste" to the Firefox toolbar but it does not work with gmail. I would appreciate you help with this and w/any features that may not be apparent.
thanks, mickey
    dell
