Recycle Bin
How to Fix the Recycle Bin Icon Not Refreshing When Emptied
The Recycle Bin provides a safety net when deleting files or folders. When you delete any of these items from your hard disk, Windows places it in the Recycle Bin and the Recycle Bin icon changes from empty to full.
If the Recycle Bin icon on the desktop does not refresh back to a empty icon when you empty it and stays the full icon, or the other way around, then this will show you how to fix this refreshing problem in Vista and Windows 7.
  • A temporary solution is to click on a empty space on the desktop and press F5 to refresh the Recycle Bin icon.
  • If you cannot Empty Recycle Bin or delete a file or folder inside the Recycle Bin, then see: How to Fix a Corrupted Recycle Bin in Vista
  • Removable drives do not use or have a Recycyle Bin. Files deleted from removable drives are permanently deleted instead.
This usually happens when the icon has been deleted by mistake and restored. For more on this, see : How to Restore the Recycle Bin back to the Desktop in Vista and Windows 7
EXAMPLE: Recycle Bin Stuck at Full or Empty
OPTION ONE
Fix Default Recycle Bin Icon Using a REG File Download
1. Click on the download button below to download the file below.​
Fix_Recycle_Bin.reg
download
2. Click on Save, and save the .reg file to the Desktop.​
3. Right click on the downloaded .reg file and click Merge.​
4. Click on Run, Continue (UAC-vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
5. When done, you can delete the .reg file (On Desktop).​
NOTE: You may need to refresh (F5) the desktop to notice the change.​
OPTION TWO
Fix Default Recycle Bin Icon Manually in Registry Editor
NOTE: You will just be temporarily changing the Recycle Bin icons to something else, then change them back to the default icons.
1. Right click on a empty area of the desktop and click Personalize. (See screenshot below)​
2. Click on Change desktop icons in the upper left corner. (See screenshot below)​
3. Click on the Recycle Bin (Empty) icon in the middle. (See screenshot below)​
4. Click on the Change Icon button.​
5. In the change icon window, click on the Recycle Bin (Full) icon. (See screenshot below)​
NOTE: For 2nd time thru after step 11, choose empty icon.
6. Click on OK.​
7. Click on the Recycle Bin (Full) icon in the middle. (See screenshot below)​
8. Click on the Change Icon button.​
9. In the change icon window, click on the Recycle Bin Empty icon. (See screenshot below)​
NOTE: For 2nd time thru after step 11, choose full icon.
10. Click on OK.​
11. Click on Apply. (Now your Recycle Bin icons are backwards)​
NOTE: For 2nd time thru, go to step 13.
12. Now go back and do steps 3 to 11 again, but time you will be picking the correct Recycle Bin icons for the empty (step 5) and full (step 9).​
13. Click on OK to go back to desktop.​
14. The Recycle Bin will now refresh again on it's own.​
OPTION THREE
Fix Custom Recycle Bin Icon Manually in Registry Editor
NOTE: This will show you how to fix the icon refreshing problem when you have used custom icons for the Recycle Bin in Vista and Windows 7.
Hello Lloyd, and welcome to Vista Forums.
Usually this will solve this problem with the Recycle Bin icon not refreshing properly. If it happens again, then repappying this should sort it again.
Update. Next day use, the Desktop Recycle Bin Icon shows Full, but there is only 1 file in the Recycle Bin. However, the principal problem I believe lies in the automatic deleting of the contents of the Recycle Bin.
I'd appreciate it if someone knows if there is another Thread that deals with how to control automatic deleting from the Bin? Here's a case where I have a disfunctional Bin, and I really would rather do it myself (when it needs doing).
Thanks
    HP Pavillioon
    AMD Phenom X4
    8GB
    HP 2150
    750 GB
You're most welcome Kate, and welcome to Vista Forums. :)
You're most welcome TM1, and welcome to Vista Forums. :)
Brink
the quick guide you have set up save me many hours of hunting for the answer before comning here...
Many big thanks for this Forum
Randy:roflmao:
    MSI K9N2 Sli Platinum MSI 785GT-E63 ASRock A770DE+
    AMD 9850 BE Quad
    MSI K9N2 SLI Platinum, MSI 785GT-E63, ASRock A770DE+
    Corsair Dominator 4GB
    MSI Ngts250 2d1g
    Samsung 24 HD
    2560x1900
    samsung, maxtor, wd
    850W Corsair
    Antec Performance One
    box cooler Plenty
    optical mouse
    cable
You're most welcome Randy, and welcome to Vista Forums. :)
