if you've lost your original recovery disks and your computer says only one copy can be made, don't believe it. just delete hpcd.sys from your hard drive (and from the restore partition). you will then be able to create another set.i need to access this partition to delete the hpcd.sys file to allow me to make a second set of recovery disks. But i cant figure out howto access it.
http://h30434.www3.hp.com/psg/board/message?board.id=OS&message.id=9035
http://forum.notebookreview.com/showthread.php?t=173304
To find the hpcd.sys, go into the folder options and make sure "hide protected operating system files" is not checked. Also make sure "Show hidden files and folders" is enabled. Then you should be able to see the files.
You must also delete from the C: drive, if you dont you will get this error:
"this computer is not capable o f creating CDs or DVDs. Contact HP suport"
- T7600G Core2Duo 2.66 Ghz
- Intel 945PM + ICH7 Chipset
- 4GB DDR2 PC2-5300 667MHz
- Mobility Radeon x1900 256MB
- Realtek HD
- WUXGA 17"
- 1920X1200
- 640GB 7200RPM SATA/RAID 0 (2x320GB) and 320GB 7200RPM External
- Wireless Microsoft 3000
- 10 mbps/2 mbps
- Other Info
- Optical Drive: Panasonic UJ-220 DL BD-RE (Blu-Ray)
