reboot problem
I have contacted a real expert in this area. I will monitor this thread to keep updated in case I can help. Have patience, you will be helped.
I can't get past the screen that you sent me a link too. I am getting the exact same screen as he is getting start windows normally, start in safe mode, start from last known settings etc. I tried them all but it keeps comming back to this screen after it trys to load. I also get ablue screen saying it is dumping something but it is to fast to read I will try to read it and let you know what it says
SF
Rich asked me to stop by and see if I could give you a hand.. Am I correct that you cannot boot in normal mode, safe mode, or from the dvd?
Let us know
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Tfirst black screen that comes up says windows failed to start,a recent hardware or software change might be the problem to fix insert disk,restart computer, click repair computer when i click to load windows normally it tries to load then for a few seconds I see the blue screen saying collecting data for crash dump beginning dump of physical memmory.
    Apevia model cdcybsq-982296
    AMD ATHLON 64x2 dual core processor 4200+
    4096mb
    Nividea gforce
    dell
    hi speed phone
Try to boot. Listen for the beeps. Tell me exactly what you hear. One beep, two, long beeps, short beeps etc. You have to work twice as hard two of us helping.
one beep
    4096mb
    Nividea gforce
    dell
    hi speed phone
See if you can boot to safe mode Try to boot during boot rapidly hit F8.
SF
Let us know
Ken
In addition, give Ken this information
Tried that but it wont go to safe mode screen
    4096mb
    Nividea gforce
    dell
    hi speed phone
OK, you did mention that before, but wanted to be sure. You did not try from any DVD, correct?
It starts to load normally untill it gets to starting acronis loader ,then i get the little bar at the bottom running from left to right as if it were starting up and then I get the black screen
    4096mb
    Nividea gforce
    dell
    hi speed phone
dont have one maybe that is the problem I must need the disk
    4096mb
    Nividea gforce
    dell
    hi speed phone
I tried the disc but the computer doesnt even recognize that there is a disk inserted, after watching the blue screen 10 or so times it says can not load the hive file,it is corrupt absent or non writable
    4096mb
    Nividea gforce
    dell
    hi speed phone
We have to set the computer to boot from the DVD. While booting, without the DVD, rapidly hit F2. If successful, you will see a screen with boot order. Give DVD/CD boot the number one position. Other choices would be hard drive etc.
You will be in BIOS if you succeed.
Then try to boot with the DVD. If not successful, while booting with the DVD hit any key during boot. Sometimes that is required.
Pressing f2 rapidly brought me to windows memory diagnostics ran the test and nothing wrong when windows restarted after test it went back to the same black and then blue screens
    4096mb
    Nividea gforce
    dell
    hi speed phone
Try it with F12. F2 should have worked. That is BIOS.
The heading on the blue screen is registry file failure
    4096mb
    Nividea gforce
    dell
    hi speed phone
OK, try with F12, lets see what happens. Turning the computer off with the on off button, should not cause all this trouble. By the way the one beep was good. Should be a software problem.
Tried f12 and nothing happens Sorry for the delay, but I only brought the tower so I have to switch back and forth from my comp to the troubled one
    4096mb
    Nividea gforce
    dell
    hi speed phone
So basically you cant log on from the dvd, cant boot into safe mode, and cant boot normally. Is that correct?
You must have been able to boot from the dvd at some point. Do you have a vista dvd, or a recovery DVD??
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
