Random Shutting Down
OK. I'd suggest you try that enough times to convince yourself whether booting to safe mode is always OK, 100% of the time.
If so, it would then be interesting to check whether not re-enabling UAC also allows you to boot to normal mode without issue 100% of the time.
It's not an attempt to find a solution, but simply to help us all understand what is happening on your machine.
well I have to go to work, but I will try that and see what happens when I get home :)
    Intel(R) Core(TM)2 Quad CPU
    I know it's made by MSI that's about it
    4gigs RAM
    NVIDIA GeForce 9800 GT
    *shrugs* RealTek I'd guess
    LCD I'm fairly certain, one corner says HDMonitor and the other says emachines.
    don't think i ever knew
    not even sure what this is
    it's pretty and i can see through one side...it glows!
    I see 2 fans.
    Also a Dell
    Not sure, it's a Dell
    Cable
    I really don't know where to find any of this information. We bought the computer online from a website that builds gaming computers. I know it's pretty and it lets me play WoW at a normal speed. If I wanna sound like I know something about computers I throw out the words "4gig Quad Core!"
I rebooted my computer into safe mode 5 or 6 times, and aside from being insanely slow everything was fine. Turned on UAC in safe mode and everything was fine.
As soon as I rebooted out of safe mode it gave me the 'Windows will shut down in less than a minute' message again.
    4gigs RAM
    I see 2 fans.
    Also a Dell
    Cable
And if you leave UAC off, can you reboot into normal mode to your heart's content without the forced shutdown?
yep, I've rebooted my computer so many times in the last few days >.< and every time I leave UAC off it starts fine, if I turn it back on the next time I reboot I get the message.
    4gigs RAM
    I see 2 fans.
    Also a Dell
    Cable
I hate to tell you, but it does seem quite likely that your machine has been infected by something.
If you enable UAC again and then use MSCONFIG to choose "diagnostic startup" mode, does the problem still happen? (let it boot by itself, don't go to safe mode this time)
It does sound like somethings trying to disable your security software.
You should download http://www.pctools.com/spyware-doctor-antivirus/ and http://www.eset.co.uk/Products. Install them and run full scans. If a virus shows up you should back up any data you want to keep and do a clean install and not just a repair, heres some reasons why When should I re-format? How should I reinstall? Security - dslreports.com
Basically once you'v got a virus the safest thing for you and everybody else connected to the internet is to do a reformat and reinstall. A repair will only fix any system files that have changed not clean the system of added files etc.
You should also go into windows defender and take a screenshot of the startup programs:
Open "Windows Defender" then click on "Tools" then click on "Software Explorer". Make sure next to "Category" it says "Startup Programs". Then take a screenshot by pressing the "Print Screen" key on your keyboard. Then open paint and paste it in and save the file. You can then upload it here and we can see if any malicious programes have installed themselves.
    4gigs RAM
    I see 2 fans.
    Also a Dell
    Cable
also am working on dl'ing those 2 programs...Quick scan with Spyware Doctor didn't turn up anything, full scan is going tho.
    4gigs RAM
    I see 2 fans.
    Also a Dell
    Cable
OK once those scans are finished. Go into Windows Defender and click on everyone of those and click on "Disable". The only 2 you should leave enabled are:
Microsoft Userinit Logon Application
Microsoft Windows Explorer
Then Reboot and see if the problem still happens.
oh wow these scans take forever >.<
I used the registry mechanic that came with one of those and got this.
Not sure if any of that means anything or it's just trying to get me to buy the product >.>
    4gigs RAM
    I see 2 fans.
    Also a Dell
    Cable
Id ignore that and just use the virus and spyware cleaners.
If you download tune up utilities (like i suggested before ;)) Its startup manager is more thorough than windows defender and you can also use its one click maintenance that will fix errors. Its the only one id recommend as i have been using it for two years without any problems and its free for 30 days.
As i already told you, Your dcom server service causing this issue. The dcom server service will use rpc(remote procedure call) frequently. Usually the rpc will open and close the tcp dynamic ports randomly. If the rpc cannot get the dynamic ports open this may happen. To rectify this problem, Open up the elevated command prompt, and type
netsh int ipv4 set dynamicport tcp start=50000 num=20000 hit enter.
This will give 20000 dynamic tcpip ports to rpc.
Let me know the result :)
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    100 mbps(office lan)
