Random BSOD (Kernel Data Inpage Error)
Got recommended to download Western Digital Scorpio Blue drive Data the .ISO of Data Lifeguard Diagnostic for dos to run from boot, and apparently this will tell me if it is actually failing, I think so anyway. Just it isn't working from the CD I burnt, so I will have to buy another blank tomorrow and re-try it with a different burning problem.
to be quite honest I don't have a clue what I'm doing with the problem, just take advice as it comes.Don't want to replace something on it, that might not even be the cause. If I get a definite problem then I can see cost of repairing against cost of replacing.
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
Try this trial software for regenerating defective hard drive sectors: -
Dmitriy Primochenko Online
Direct download link: -
http://www.dposoft.net/products/hddreg/2011/735798276/hr2011.exe
Once downloaded it will create a boot Flash or CD drive
Note: -
Only one sector can be recovered from a trial disk but at least you will know if the disk is failing!
With the state of his hard disk (assuming that it is indeed the harddisk), this software will not help, and chkdsk will do just as well. At this point, we need to confirm that it is the hard disk (and not some other piece of hardware which is broken), hence why we are running that software.
@Eastwood: Wrench97 is giving you excellent advice over at TSF. They will get the software they asked to be run running.
I am sorry that this is dragging on. Let VirGnarus and Wrench97 test your hard disk. They will get your hard disk sorted out, and they are familiar with the software they have recommended.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Okay guys thanks so much for your help! It's nobodies fault but my own niemiro that this isn't fixed yet, everybody has give me their best advice, but problems like this are obviously very complex and doesn't help i'm a bit of a novice!
I will try to burn the file onto a cd again, but don't have any here with me so again I'll have to come back tomorrow!
Thankyou again, enjoy your evenings chaps!
Hello again!
I shall show you one tip, which doesn't explicitly relate to this problem, is more general, but is good to know nonetheless. You can actually re-use CD-R/DVD-R disks.
Insert the disk into the drive, and on My Computer (without the My these days!), right click on the disk and click Format. Complete the format operation (being VERY careful not to format the wrong disk or hard disk). Once it has completed, the disk will be blank again.
There is one slight snag: the maximum capacity of the disk will be reduced by the size of the files which were on there, and so this trick can't be used forever, or repeatedly on disks with lots of files on them, but it can draw extra life out of those disks.
Just a little tip of the day!
Richard
P.S. Although this doesn't work on absolutely every disk, it works on most.
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
niemiro, I love that, never knew you could with CD-R disks, thanks for future reference. It has deleted the information, other than the name I gave to the CD but unfortunately won't let me write on the disk again (JVC by the way is the make.)
Anyway, I again burnt the programme to disk, and why I do not know but the laptop still is not booting from the CD, could this be due to the problems the computer is having? It's definitely set to run from DVD drive first.
Thankyou all
By the way, just went and enabled the boot options under main in BIOS and upon pressing F12 it comes up and I asked to boot from CD and again just skips straight to Windows start
This means/ tells you that the disk is not a boot disk! It must just be a data disk or something.
Please wait for the correct format of disk to be provided as detailed by niemiro.
    40 Meg
Thankyou all
Shame about that. All I know is that it worked on my disks(!) when I first discovered that trick. Not that it does you a lot of good! I guess I was lucky and had disks half way between this and that! Choose 1 or 0: half: sigh...
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Okay, bad news!
Test Option: EXTENDED TEST
Model Number: WDC WD5000BEVT-22ZAT0
Unit Serial Number: WD-WXNY08S90088
Firmware Number: 01.01A01
Capacity: 500.11 GB
SMART Status: PASS
Test Result: FAIL
Test Error Code: 08-Error was detected while repairing bad sectors.
Test Time: 18:56:14, January 02, 2012
It did say they may be repairable, however I attempted this and after a few seconds said error contact WD support. Am I finished? Any ideas?
    40 Meg
