You're wrong Everlong.
FAQ
They have to be the same GPU, but not necessarily the same memory.
Can I mix and match graphics cards with different sizes of memory?
While it is not recommended, NVIDIA does offer this flexibility using Coolbits. When purchasing a second graphics card, you should try to match the memory size so that you are ensured full value and performance from your purchase. For example, if your first card is a GeForce 6600 GT with 128MB of memory, you should purchase a second GeForce 6600 GT with 128MB of memory. However, using Coolbits (value set to 18), you can force both of the cards to use the lower of the two memory sizes and operate together in SLI mode. When dissimilar memory sizes are enabled to work together using Coolbits, the effective memory size for each card becomes the smaller of the two memory sizes. Instructions to enable this feature can be found here.
I know about coolbits, just in general they need to be the same memory value, otherwise use coolbits, though like it will run at the lower memory value.
The times I've used SLI (with 6600's and 7600's) I've always just used both the same brand/type of cards. And getting the same XFX 8800GTS at the end of the month for SLI again.
 - Custom Built
 - Intel Core 2 Quad Q9550
 - XFX MB-750I-72P9 NF750i
 - 4096MB Corsair XMS2 PC-5400
 - ASUS Nvidia Geforce GTX470
 - ASUS Xonar DX
 - Dell 24" S2409W & Dell 20" E207WFP
 - 1920x1080 & 1680x1050
 - 750GB Western Digital Caviar Black & 500GB Samsung
- PSU
 - 750 watt Thermaltake Toughpower
- Case
 - Coolermaster Dominator 690 Nvidia Edition
- Cooling
 - Zalman CNPS9700-NT Cooler, 6x 120mm Chassis Fans
 - Logitech G5 Laser Mouse (2007 edition)
 - Logitech G11 Keyboard
 - 100Mbps
- Other Info
 - abit airpace 54mbps wireless PCI-E x1 card
