I was just going over my computer specs and decided to make a post about some temps.. and see what everyone else is getting.
If you have a Quad Core, Preferably a Q6700 or Q6600 Please post some temps you have.. as I built my system, and one for my brother.. mine is done. and I just finished his. His Antec 900 i kno is a better cooling case than mine, but that systems Temps are much better than mine so I'm thinkin I might need to try and Remount my CPU.
Right now I'm on a Q6700 OC'd to 3.33GHz and I'm getting an Idle around 45C when I first loaded my machine first time ever, stock temps based on the BIOS reading was 42C or so.. now I've just finished my brothers last night.. and in the BIOS for the first time on his he gets a temp of 29C and never went above 31. thats a big big difference, and I really want to get somewhere close to those. I kno my OC makes it hotter, but shouldn't be that much hotter.. we both are using the Tuniq Tower w/120mm fan (Anyone replaced that fan, and what with)
So I was hoping to see some other peoples Q6700 temps, stock, OC'd, idle, and Max.. whatever you have, Screenshots. or what not. everything is welcomed. I'm thinkin I might try and remount my CPU and add a little more thermal paste. I put a slightly bigger drop on his than mine, that might be helping.. So please post some Temps..
Thanks!
Thanks!
- Q9650 E0 4.0 GHz @1.304v
- eVGA 750i FTW
- 2x2GB Corsair Dominator PC2-8500C5D
- eVGA/MSI GTX 260 SLI
- X-Fi XtremeGamer
- Samsung T240 & 226BW
- 1920x1200 & 1680x1050
- Seagate Cuda 500GB 32mb Cache SATA 7200.(11) + 500GB Seagate Cuda External eSATA, USB, FW400
- PSU
- PC P&C 750w Silencer PSU
- Case
- CoolerMaster HAF 932 (Water-Cooled)
- Cooling
- Plenty of Fans, and a few 230mm Fans
- Logitech MX-518
- Logitech G11
- Other Info
- ASUS 20x Optical, Bose Companion 3, ATH-AD500 Cans :), Patriot Xporter 16GB Flash Drive (Very Fast), & Sandisk Micro 8GB. Nikon D40 DSLR with 18-105mm VR & 55-200mm VR
