puzzled ethernet, usb, idk.
Re: puzzled ethrnet, usb, idk.
OK you do not have Ethernet connected.
Cable (Ethernet) is a wire from the street to your house that goes into the back of your modem with another wire going to either a Router or directly to your computer.
What you have is Wireless (not as fast) and all I could advise is to go to device manager and see who makes your network adapter. Go to their site and download the latest driver from there and install it. Don't use update driver in Device Manager until you have downloaded it.
Then go to Device Manager and update the driver. When it asks if you want to search your computer or go on-line pick search your computer and go to the downloaded file.
Did MalwareBytes find anything?
I don't think Namebench will help you on Wireless.
If you can I would change to Cable Broadband as when I was on Wireless the best download speed I ever had was only 140KB/Sec
On cable I now get 15MB/sec Download and 2MB/Sec upload.
Huge difference and turned out much cheaper as well with my 40Gig data cap a month costing $69
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
ok il try that, yea maleware has found 5 threats so far,
    toshiba satellite
    Intel Pentium T2080 @ 1.73GHz 66 °C Yonah 65nm Technology
    TOSHIBA ISRAE (U2E1)
    Generic PnP Monitor (1440x900@60Hz) Mobile Intel(R) 945 Expr
how would i go about finding the most resent one, pantech um185 wwan driver? i dont know how to find the resent 1
    toshiba satellite
    LENOVO 64734VM
    15 inch
I see the problem, it's a 3G modem people, just google "cricket broandband modem" and it comes up with a 3G dongle, your speeds are bad because you are using the same network as your cellular telephone, no amount of driver updating will help you get a faster speed unfortunately, you would need cable or standard phone service to receive a faster speed Jason, sorry.
MrNeeds
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Yes I tried a Merlin Express Card and a USB and then switched to cable and never looked back.
    LENOVO 64734VM
    15 inch
well thanks for all u guys help, ima go with comcast friday dont c anyway around it, cricket was cheap payd like 30 a month,
    toshiba satellite
To sort the problem of songs buffering start the song and press pause then after it has finished or near to finished downloading press play and it will play without pauses.
    LENOVO 64734VM
    15 inch
