(programs and features) Hanging !
This is the last...
import 9.reg to registry - if problems again appear import 9_undo.reg to restore previous settings
I check It and it work fine but still there is programs missing,
and some program are NOT in the list, I try to reinstall again but It dose NOT complete the sutep !
I'm sure you give you already all parts.There is easy way to check definitly - again export key
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
and upload it on speedyshare.com and compare it with key in post 21.Mention all programs which you can't see.
yes you are right !
VMware Workstation is not in list
in in both post 21 and now but It's already installed in my PC !
Look:
this when I tried to reinstall it again !
yes you are right !
But VMware is listed HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall ->in x32 key it is x32 not x64.Check does Windows Installer Cleanup can see it ->if yes use it to remove VMware and try install again
wooooooow
with this tool: " MyUninstaller " all my programs appear on it ,,
I will unistall all the programs that NOT appear in (programs and features) and I will intall them again ,,
And will see what happned ,,
My Dear Flavius,,
Now it's OK I reinstall All programs that NOT appear in (programs and features) and the appear fine, accept three programs "VMware Workstation 6", "Nokia PC Suite" and "PowerDVD" I can't reinstall them again !
It show me what say's : This program is already installed in your system.
but in the (programs and features),(MyUninstaller), (TuneUp) and (Your Uninstaller! 2008) there No key for uninstall these three programs !
* Can you Help to remove them ?
Also I am facing "BlueScreen" and "shut down unexpectedly"
and I analyzed the Files that help describe the problem which is "xxxx.dmp"
I will put Pic to see by yourself more clearly:
"ntoskrnl.exe", "atapi.sys" and "ecache.sys"
These files probabley are the cause of the problem !
VMware
Navigate to folder:
C:\Program Files (x86)\VMware\VMware Workstation
and find file like uninstall.exe,setup.exe or so likely and run it - in this folder should be any uninstaller to this program
Nokia PC Suite
C:\Program Files (x86)\Nokia\Nokia PC Suite 7
also look for file like uninstall.exe,setup.exe or likely
PowerDVD
C:\Program Files (x86)\CyberLink\PowerDVD8
also look for file like uninstall.exe,setup.exe or likely and run it -it should be any uninstaller in this folder also.
You can also try check Start>>All Programs>><program name> <-sometimes there is shortcut to uninstaller any program
These BSOD don't look good.It looks like any hardware trouble.Uninstall above programs and don't install them again and watch your system -If BSODs appear again copy items to notepad and attache here.Check also your system condition
http://www.vistax64.com/tutorials/69535-reliabilty-monitor.html
Unfortunately there is no file for uninstall like that in VMware Workstation folder !
See:
for Nokia and PowerDVD folder for them Does not even exist !
See:
also in Start List there is no key for uninstall !
