Problems installing updates for Vista x64 Ultimate
necro,
Download the hotfix from this link and try again..
Tried that one. I get a message saying: "The update does not apply to your system".
I'm still working on the hardware problem. So far I have eliminated the HDD. I used chkdsk and WD Data Lifeguard Diag software. They both found no problems. I will try removing some of the cards today.
    Myself
    Intel Core2 Quad Q6600 2.4GHz
    EVGA Nvidia NForce 680i SLI
    2x OCZ 2N800SR4GK PC2 6400 Dual Channel Nvidia SLI
    EVGA Nvidia GTX 260
    Onboard Realtek High Definition Audio
    LG 32LG30 HDTV
    1300 x 768, 1080i
    RAID 5 w/ 3x Western Digital WDC WD80 0JD-00LSAS 1x Seagate ST3160811AS
    Cooler Master 1000W
    Cooler Master CMStacker
    Logitech Cordless Mouseman Optical
    Logitech Cordless Elite Duo
    LG BlueRay/HD DVDRW GGC-H20L Lite-ON DVDRW LH-20A1L Logitech DiNovo Mini Logitech Rumblepad 2
You have nothing to do with removing your hardwares..... Its clearly a bad combination of your ramsize and motherboard with your vista...
Go to control panel >classic view>program and features>view installed updtes if kb929777 is already installed, uninstall it first.
Restart your computer, install kb929777 manually. Restart your computer and chec for updates through windows update.
If anything offered for u install that too. Restart your computer probably you will not get bsod
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    100 mbps(office lan)
I don't see any Vista OS updates on that list. I attached screenshots of the windows updates screen to show which updates I keep getting. I try installing them but they keep reappearing.
    Myself
    EVGA Nvidia GTX 260
    LG 32LG30 HDTV
    1300 x 768, 1080i
    Cooler Master 1000W
BSOD is no longer a problem when taken down to 2GB memory. The only problem I have now is installation of updates. As far as I know, no updates will completely install on my computer. I either get an error message or a message saying that I don't need the update. I am beginning to think I may have a virus and need to reintall the OS and format the hard drives. If that doesn't work, I guess I'll have to go back to XP. I can't underdstand why MS would release an OS that will only work with 2GB of memory, that's just crazy.
    Myself
    EVGA Nvidia GTX 260
    LG 32LG30 HDTV
    1300 x 768, 1080i
    Cooler Master 1000W
Have you tried one stick of ram at a time ?.
Put in one, then if it works OK put in another one, and so on till you get an error.
If you get an error remove the stick of ram and try another one.
I have eight Gig of ram with no errors, so Vista will run with a lot of ram.
It could even be the ram slot on the Motherboard.
Try this and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Ok, just finished with the memory. I tried putting each stick in each slot. Every time it booted up to windows with no problems and no bsod. So, everything seems to check out. Please pardon my incompetence, but why would the RAM prevent the windows updates from installing properly?
Aslo, I noticed that there isn't anything listed on the Windows features screen.
    Myself
    EVGA Nvidia GTX 260
    LG 32LG30 HDTV
    1300 x 768, 1080i
    Cooler Master 1000W
Something is corrupted in HKLM\Components or HKLM\Software\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages.Navigate to HKLM\Components and make sure this key looks like by me:http://www.vistax64.com/872713-post6.html
apart of them:
Run cmd.exe with administrative previlliges and type
sfc /scannow
when it will done create report
findstr /c:"[SR]" %windir%\logs\cbs\cbs.log >%userprofile%\Desktop\sfcdetails.txt
on your desktop appear file sfcdetails.txt
next run CheckSur Description of the System Update Readiness Tool for Windows Vista, for Windows Server 2008, for Windows Server 2008 R2 Release Candidate, and for Windows 7 Release Candidate
even if this tool won't resolve problem automatically it create logs:
C:\Windows\Logs\CBS\CheckSUR.log
Both sfcdetails.txt and CheckSur.log attache to post
Before I start messing with the registry, am I supposewd to delete anything that isn't exactly the same as your picture? The only value that is the same on my computer is the last one... StoreFormatVersion
    Myself
    EVGA Nvidia GTX 260
    LG 32LG30 HDTV
    1300 x 768, 1080i
    Cooler Master 1000W
On first view only ccpinterface key is missing -Installers key is only temporaly key.Import fix which I attached below -although I doubt it is really issue - I suspect the problem is any deeper subkeys in HKLM\Components or HKLM\Software\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages.After importing post here checksur.log and sfcdetail.txt what I asked in my previous post
First off, last night my computer was running with no bsod. Until.... I intalled my bluetooth dongle. After that I started getting bsod during startup and after recovering from hibernation. I took it oout but bsod still continues to happen.
Second....I ran that fix u gave me and it didn't work. I got a message saying it could not access the registry.
Also, I could not get CheckSur to work either. I downloaded it, installed it, and nothing happened. I do not know how to run the CheckSur program. I believe I already mentioned that in another post. I put CheckSur in both cmd and the run box. When I put it in run, a folder with a bunch of cabinet files popped up. Plus, I searched for and could not find the CheckSur.log file. I did however run sfc /scannow and the log is attached below.
    Myself
    EVGA Nvidia GTX 260
    LG 32LG30 HDTV
    1300 x 768, 1080i
    Cooler Master 1000W
n.
It was my fault in this fix -I confused paths in registry thus you had this error during importing -sorry.Under post area you have corrected fix.Import it +restart.If after importing CheckSur still won't work run cmd.exe with administrative previlliges (right click on this file as admin) and type
REG EXPORT "HKLM\Software\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages" %userprofile%\Desktop\Packages.txt
and next navigate to C:\Windows\Servicing\Packages
C:\
cd\
cd /d C:\Windows\Servicing\Packages
and list containers
dir /s >%userprofile%\Desktop\Packages_files.txt
On your desktop appear files Packages.txt and Packages_files.txt ->upload these files on rapidshare.com because these files will be too big to attache here
I imported the new file and it worked. CheckSur still doesn't work.
    Myself
    EVGA Nvidia GTX 260
    LG 32LG30 HDTV
    1300 x 768, 1080i
    Cooler Master 1000W
I checked these files and nothing wrong found.Whatever it is I recommend Repair Install http://www.vistax64.com/tutorials/88236-repair-install-vista.html
without loosing programs and data
Didn't work. When it restarts it goes to bsod. I have to remove the upgrade in order to boot into windows again.
Try updating your windows update agent. This link will help u :)
windows update agent is my biggest problem. I have it installed, but updates won't install properly.
    Myself
    EVGA Nvidia GTX 260
    LG 32LG30 HDTV
    1300 x 768, 1080i
    Cooler Master 1000W
Follow this link to make checksur to work for u. and upload the checksur.log file :)
Using CheckSUR to repair Windows Vista update problems « the back room tech
Do you people even bother to read my previous posts?
I've already tried to install Update KB947821. It did not work.
Anything that is a Windate Update will not install on my system properly. I will get a successful install message. However, when I restart it's like I never installed it. It almost seems like Vista is automatically starting from a previous restore point when I restart.
    Myself
    EVGA Nvidia GTX 260
    LG 32LG30 HDTV
    1300 x 768, 1080i
    Cooler Master 1000W
I described the proper way of installing the checksur manually.
You need to delete the checksur registry key and add a key mentioned in that article.
Follow the steps mentioned after the download link for kb947821.
Try that. :sarc:
    Wipro
    Intel dq35j0
    8 Gb
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
Yeah, you got me. I did not read the whole article the first time. I just finished following the instructions exactly. Guess what....it's a big surprise here. IT DID NOT WORK. CheckSur fails to run after installation. This is the fifth time I tried installing it. Anyone got other ideas besides doing a clean install?
    Myself
    EVGA Nvidia GTX 260
    LG 32LG30 HDTV
    1300 x 768, 1080i
    Cooler Master 1000W
