That is by far the strangest thing I've ever seen...how in the World did you manage to get all those 0MB Unallocated space/partitions...???
That's a new one for me and I've seen just about everything...
Anyway, as stated before, if you format C:, than all you do is format C: and nothing else. If you format the entire drive, you lose everything, including all the data you want to save.
So you have a couple of options.
1- Do as ScsiRaidGuru says and get some sort of external storage to move your needed data too, and then overwrite this entire drive using an Eraser program that will also overwrite the MBR and MFT of the drive, then start clean. ActiveKill Disk works good.
2- Use a 3rd party partitioning tool to create a 150G partition on this drive, then transfer your data to it and wipe out everything but the drive letter that shows it's 150G's in size...
Be warned that sometimes Windows has a hard time recognizing NTFS formatted partitions when it's been created by something other than the Windows partition tools. I've had NTFS partitions created by Partition Magic and Windows has refused to recognize it as such and wants to format it again before it will use it.
GParted is an Excellent tool, and I would definitely try that to carve out a partition big enough to store your needed data. Remember tho, when you reformat...everything BUT that new partition must be formatted or you may end up with those weird unallocated spaces again....weird...just plain weird!
Oh yah...always remember that Formatting does NOT actually delete any data...it only removes the headers from the Master File Table to make Windows think that the space is empty and therefore useable. None of the data is actually "Gone" until it is physically overwritten by other data. That's why Eraser programs are best when dealing with weird looking things like you have, since they physically overwrite the entire disk, including the reserved MBR and MFT areas if set to do so. That should take care of those 0MB unallocated spaces you have if a simple reformat doesn't do the trick for you.
- Personal Build
- Intel E6750 Core 2 Duo
- Asus Commando MoBo (P965/ICH8R)
- 4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
- BFG 8800GTS OC2 320MB
- Creative Sound Blaster X-FI Platinum FATAL1TY (next)
- 2 x 22" w2207 LCD Monitors
- 1- 1680 x 1050, 1 - 1920 x 1080
- 3 x 500G SATA II WD Caviar HDD's
- PSU
- EnerMax NoiseTaker II 600W
- Case
- NZXT Lexa Classic (modified, dual doored & windowed)
- Cooling
- Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
- Logitech Optical Trackman trackball
- Other Info
- NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
