Problem instaling Adobe reader 9.1
So your computer is running properly apart from the Adobe, iTunes glitches?
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
Not really, when i turn on UAC most of the icons in the task bar dissapear but when I turn UAC off all those icons come back. For example with UAC on my mouse pad scrolling action does not work but it works with UAC off. With UAC off my Trend Micro task bar icon disappears so I dont know if I'm being protected.
Looks as though we need to delve into your computer history further.
When you purchased your computer did it come preloaded wirh an Anti Virus Program? If so what was it & how did you uninstall it?
When did you first notice the glitches that you have now?
Is the computer fully updated? [ Windows, Security etc.]
Have you done all of your computer housework regularly? [defrag, disk clean up, error checking, computer back up.]
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
The laptop is an HP Pavillion dv6700 running vista 64 bit, is about a year old. I am sure it came with an antivirus program and I deleted the program thru control panel; programs and features. I do not remember which antivirus software program, The computer is fully updated with latest security patches. The only updates that are no able to install are Zune 4.0 and Office Live ad In 1.4. The last successfull update installed was a definition update for windows defender on 17 Sept.
Dfrag is done thru schedule. Clean up is done thru Trend Micro. Error checking not in a long while. Back up only pictures and music.
Last year I installed a program called Tversity (used to stream music and videos to xbox and ps3) I had to turn off UAC for this program to work. It was the first time I uninstalled UAC. After getting bored of Tversity I uninstalled thru Control Panel but left UAC off. I started to notice problems when the latest version of Adobe reader came out and I was asked to update. Then the problem escalated to the iTunes version before this last one.
Having purchased three HP laptops over recent years myself, yours would certainly have had an Anti Virus Program on it. [Probably Norton] The reason I'm asking this is - if you didn't use the appropriate Removal Tool [ as distinct from Control Panel etc.] there could well be remnants of the original AV still lurking on your computer. These remaining remnants are well known to create problems.[However the problems are usually seen fairly early after uninstalling the original AV.]
I suggest you run both lots of check disk asap & would recommend that you back up your whole computer too.
I hope you meant turned off UAC.;)
Have you a system restore point prior to when you started having these problems with Adobe & iTunes?
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
While you are doing that, checking the RAM would be a good idea too.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Yes I meant turned off UAC. Check disk did not find any problems.
to note i tried to to an update and it failed as well i have adobe reader 9.0
after i failed on the update,reader itself did not work
i uninstalled reader, did the microsoft install cleaner, searched the h/d for adobe files
and deleted them. rebooted and installed reader and the updates no problem
that work for me hope thing work out for you
p.s. adobe seems to do this every now nad then
    homegrown
    intel core2 quad Q6600 2.4ghz
    gigabyte x38t-dq6
    4gb ddr3 Corsair TWIN3X2048-1333C9DHX
    nvidia geforce 8800gt 512mb
    Realtek ALC889A codec
    samsung 21.3 screen
    1024 by768
    500gb wd hd 250gb wd hd
    Corsair CMPSU-750TX
    Arctic Cooling Freezer 7 Pro
    microsoft wireless mouse 7000
    microsoft wireless keyboard 7000
    cable 850
    pioneer dvd-rw dvr215d lite-on cd-rw sohr creative inspire pt7800 7.1 plus 2.1 addtional speakers hp officejet j5750
same problem tht i'm facing. When ever trying to install the flash player getting problem like operating system error!(16248.203.296-7327........) and also when installing activex control displaying tht windows cannot access the specified device,path or file. You may not have appropriate permissions to access the item (while opening in firefox)
Hello sudhirv & welcome to our forum,
If you wish to receive help with Adobe Flash Player I would suggest you start a new thread rather that tag along on this Adobe Reader 9.1 one.
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
