Problem after installing Updates Agent 7.6.7600.256
Doesn't wsus offline download the updates from MS? Presumably that won't be happening after August 3rd.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
I have just tried wsus offline. Tried using it to update frshly installed Home Premium x86
First tried the 924 version.
It sticks at svchost jammed at 25% cpu
Then tried the 1092 version. The same . Jams with svchost stuck at 25%.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Afraid it doesn't help.
wsusoffline gives the impression that it will update the installation. Sadly, that doesn't seem to be the case.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
What's interesting is that, after I installed the ISO from Ex_Brit, Windows update found like 5 updates and installed them. I believe that's what took me to the .6003 installation but I'd have to review the other thread on this. I won't install the 2008 Server updates since that's what I was doing when the MBR got screwed up. Note that I have 64 bit.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
You’re running build 6003 but you won’t install any Server 2008 updates!? That’s a good one wither 3. Yeah, you should probably “review the other thread” sometime.
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
Hey, everything is working. If it's ain't broke...............................
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I couldn’t agree more!!! :shock: My memory might be just a tad better than yours though. In a nutshell, you are running build 6003 because you took Microsoft’s advice instead of listening to this forum’s naysayers. (The ironic part is that you are nevertheless one of this forum’s naysayers.) Didn’t you have to buy a new hard drive to finally solve your MBR problem? What if it was a hardware problem that had nothing to do with Server 2008 updates? I also recall that you found PUPs on your previous installation shortly before you concluded post hoc that Server 2008 updates were the cause of your problems.
    Intel Q6600
    3 GB
...wsusoffline gives the impression that it will update the installation. Sadly, that doesn't seem to be the case.
Hi SIW2:
Thanks for testing, even if the update wasn't successful. I tried posting in the WSUS Offline Update forum a few days ago to ask if ESR versions of this tool will still work with Vista SP2 as of 03-Aug-2020 when Microsoft starts enforcing their SHA-2 code signing policy but my forum account has been deactivated (I haven't posted there for a while). I tried to reactivate my account but my reactivation code never arrived in my Inbox; I also tried creating a new forum account using a different username and email address and that activation code didn't arrive either, so I can't even PM the Forum Mods to ask what's going on.
I did find an a pinned post called wsusoffline "Community Edition" discussing "the future of WSUS Offline Update" which states in part:
"An adjusted version of wsusoffline 12.0 and 11.9.1 ESR, which get current updates for their static definitions, is available here:
12.0 -> https://gitlab.com/wsusoffline/wsusoffline/-/releases/12.0_CommunityEdition
11.9.1 ESR -> 11.9.1esr_CommunityEdition · aker@wsusoffline / WSUS Offline Update
This version ist equal to the official wsusoffline-builds, exept for it downloading its static definitions from GitLab instead of wsusoffline.net...
At this point I have no idea if this ESR v11.9.1 "Community Edition" posted on GitLab actually behaves differently than the latest "official" ESR v11.9.1 build (rel. 12-Mar-2020) at WSUS Offline Update - Update Microsoft Windows and Office without an Internet connection or why this "Community Edition" was even created.
32-bit Vista Home Premium SP2 * Firefox ESR v52.9.0 * Malwarebytes Premium v3.5.1-1.0.365
    32-bit Vista SP2 Home Premium
    HP Pavilion dv6835ca
    Quanta 30D2 (U2E1)
    3 GB RAM
    NVIDIA GeForce 8400M GS
    64-bit Win 10 Pro v22H2
    Dell Inspiron 15 5584
    Intel i5-8265U @1.60/1.80 GHz
    Dell Inc. 07R8NW
    8 GB DDR4 SDRAM
I have updated my installation manually - took a little while to do all editions of both bit versions.
It would be good if there was something like simplix update pack for vista.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
My updated media installs with these included ( this is home premium x64 )
WU shows 3 optional only. NetFrame 4.5.2 is not integrated, because 4.6.1 ( or higher for the more adventurous ) can be installed afterwards
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
This might be a way to do it, but it requires having the updates already
That is not how I did it, but it looks like it might be a better bet than trying to get wsusoffline to install them.
Another way:
Integrate 151 updates into the install.wim image.
Install to a spare partition
Press ctrl+alt+F3 at the first oobe screen to reboot into audit mode.
Run the 4 "speedups" - those can't be successfuly integrated.
Reboot.
Install the rest of the updates, and any drivers , rebooting where necessary ( still in audit mode)
When done, tick the generalise box and select reboot to oobe.
Don't reboot back into that vista partition - instead boot into another os.
Capture the updated vista partition into an install.wim file using any number of tools. I prefer to use wimlib.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Too bad the average user is even less likely to have a custom ISO than a Macrium image. How to break the bad news to them when they post? My writing seems to offend some people, so I have resolved to use more emojis:
I deeply regret to inform you that Microsoft no longer provides updates for Windows Vista because their old hash algorithm was insecure. Have a nice day! :D:
    Intel Q6600
    3 GB
It is 4 August and these downloads still seem to be working
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Hi SIW2:
As far as I know all those updates are dual-signed (SHA-1 and SHA-2).
When I read the Microsoft announcement SHA-1 Windows Content to be Retired August 3, 2020 I assumed they were only referring to updates and other content on the Microsoft Download Center with digital certificates that only use a SHA-1 hash. Does anyone know for certain that dual-signed (SHA-1 / SHA-2) content is also going to be removed from the Microsoft Download Center, and if so does this affect the updates on the Microsoft Update Catalog and Windows Update servers and as well?
    Quanta 30D2 (U2E1)
    3 GB RAM
    Dell Inc. 07R8NW
    8 GB DDR4 SDRAM
I also checked the first few in my my pre-integrate list and they seem to download fine.
Windows patch Loader still offers to download all.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Might be the end for vista updates via WU now. Getting errors trying WU today 7 August 2020.
Looks like the simplest thing is to use installation media that has already been updated.
Or maybe somebody will make an update pack. Winfuture.de has one for x86, but they haven't changed it since 2014. Maybe somebody else will make one.
The .cab files are still available via windows patch loader.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Aren't the ISOs provided by Ex_Brit suitable or are you talking about installing the server 2008 updates?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
"Aren't the ISOs provided by Ex_Brit suitable"
Looks like there won't be any updates for those via WU. None.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Much depends on how long Microsoft permits activation for legacy versions of Windows that are no longer served by Windows Update. (We await the OP’s next post in Error Code 0x80072F8F when trying to activate Windows Vista in that regard.) For those with existing Vista installations, an image or better yet a clone of the system drive has long been my recommendation.
    Intel Q6600
    3 GB
