Potential problem/situation, hacked?
Ive fixed every program except 1. When I reinstall with the latest Sun Java, the threat goes away, but as soon as I rescan it pops back up. I did manage to fix all other threats though.
BTW, I HUGELY appreciate you taking the time to help me.
Updating Java:
  • Download the latest version of Java Runtime Environment (JRE) 6.
  • Scroll down to where it says "Java Runtime Environment (JRE) 6u21 allows end-users to run Java applications".
  • Click the "Download" button to the right.
  • Check the box that says: "Accept License Agreement".
  • The page will refresh.
  • Click on the link to download Windows Offline Installation with or without Multi-language and save to your desktop.
  • Close any programs you may have running - especially your web browser.
  • Go to Start > Control Panel double-click on Add/Remove programs and remove all older versions of Java.
  • Check any item with Java Runtime Environment (JRE or J2SE) in the name.
  • Click the Remove or Change/Remove button.
  • Repeat as many times as necessary to remove each Java versions.
  • Reboot your computer once all Java components are removed.
  • Then from your desktop double-click on jre-6u21-windows-i586-p.exe to install the newest version.
    Intel(R) Core(TM)2 Quad CPU
    INTEL/D975XBX2
    ATI Radeon HD 2600 Pro
    Samsung SyncMaster 914v
    1280 x 1024
    2/500GB each ... ST3500630AS ATA Device. One is not connected
    Rocketfish 700 W
    G.Skill Gigabyte Chassis
    Microsoft PS/2 Mouse
    DSL
    ATI HDMI Audio
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
Fingers and eyeballs crossed for ya' :D
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
Keep everything up to date and be careful where and what you search for! Everything should be fine. :)
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
