Please help, with Vista Startup registry corruption
I think the consensus is that your Vista installation is corrupt enough it would take a lot of specialized work to fix it. I suggest a reinstall; at this point it is what I would do. Either back up your files using another computer or us a live linux distribution such as knoppix or ubuntu and save to an external hard drive. If it where me I would not put XP on it.
I think it's interesting that a dvd worked whereas a cd wouldn't.:sarc:
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Good luck.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
Try a regular CD.
Reinstalling Windows may help - but if it's a hardware problem it may not.
I suggest that you run the hard drive diagnostic before trying a wipe/reinstall.
The old files will be in the Windows.old directory.
OK, I need just a bit more advice now. I have come to grips with the fact I need to reinstall Vista. I have pulled all my info off of the hardrive and went to system recovery (via F8 Repair). I wanted to go this way because if I can install back to factory settings, then at least I would still have the programs that came with the computer (like Norton, MS OFFICE etc.) But it is asking me for a password and I never set a password?????? I have a DVD for Vista (my father's machine, not mine) when I wanted to try and run the restore, but I dont have one for my machine or my software (that came installed), because they never sent it.
I have the Vista product key on the machine BTW.
Suggestions please
Compaq DVD's aren't interchangeable. You can't use one on another model machine. If it's the same model, it'll work.
If your Dad's computer is not a Compaq/HP, it may work. Let me know what make and model your Dad's computer is.
Is there a dialog that asks you to select the account to use? If it says "Administrator" that's the wrong one. Scroll down and choose your user name and see if that works without a password.
While you may be able to use the MSOffice from the restore, I wouldn't suggest trying to use the Norton. It's way too old and is likely to cause problems for you.
My father's computer is not a compaq. Its a dell. The CD I have from him is the Vista Home Premium SP1. That is the same OS on the compaq.
Is there a dialog that asks you to select the account to use? -No
If it says "Administrator" that's the wrong one. Scroll down and choose your user name and see if that works without a password. -Only gives me the user name option. I tried to leave it blank, and typed: password or admin and nothing lets me in.
Have fun getting all the updates.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
That doesn't matter. Since it isn't a retail disk that you bought it is against Microsoft's terms of use to use in another computer even if it isn't installed on the computer it came with (read the fine print). In addition OEM copies from manufacturers are set up for the manufacturer's computers and probably also for a specific model. The drivers and registry settings will be incorrect when used on your Compaq and it will not work correctly. You very well might end up with blue screens and system freezes. In addition the manufacturer might have included in the disk a hardware check which would determine that you are using the wrong computer and therefore refuse to install. You must use either a retail disk or what came with the computer.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
Update: I was able to use the Windows Password Reset and get into the System Recovery. It has set my computer back to default/factory settings. I am now going though the tons of updates. 125 so far, and so far so good. Thank you all for your help. I will now spend tomorrow putting all my crap back on, that I was able to pull off my harddrive using Apricorn - DriveWire Universal Hard Drive Adapter - Metallic Red- which is a nifty little thing.
Thanks again :)
Good job. I prefer a hard drive enclosure because it protects the hard drive better.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
