Please Help.... Vista is NOT Vista, Please Read...
I have no idea what to say about Server or 7, Server is non-standard and not for general public use as an everyday operating system, 7 is supported on SevernForums not here. If you put in a new hard drive it wont boot to anything as it's blank. You would need an operating system DVD to boot it to in order to freshly install the system from scratch and that means probably purchasing one, plus that's assuming the system will boot from a DVD. Then the question arises is the machine capable of doing that. Only a good PC repair shop would know that by physically looking at it and testing it.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Good luck ;-)
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
On a Dell system, You can reset it to the factory configuration. If I remember correctly, you would hit F5 repeatedly during the boot and then hit F8 to get to the recovery options. However, You would lose all your files and software that's on it and you would have to install all the updates that have come and gone since you bought it.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
