Photoshop CS3 & Dreamweaver CS3 work on Vista X64 SP1?
This is the purchased version and did try the installation on both C drive and external to see what results I'd get. Both installations responded the same way. I even disabled my microsoft services in MSCONFIG and attempted the installation.
most recently I did the following:
[FONT=&quot]Click Start in bottom left
Search for cmd
Right click and run as administrator
type or copy and paste
cd C:\Windows\SysWow64
then copy and paste
regsvr32 jscript.dll
then copy and paste
regsvr32 vbscript.dll[/FONT]
Still continued to get the same results.
    DX4200-UB001A
    AMD Phenom 9950 Quad-Core Processor 2.20 GHz
    6.00GB
    Cable
Hi Alpha Wolf,
Even though some people have gotten Photoshop CS3 to run on Vista 64, (I myself run CS2 fine under x64), there are some CS programs that will not run under Vista x64, I believe Adobe Flash is one such example.
Have you called or checked Adobe's website to see if the CS3 Master Collection has issues with Vista 64? Or...which programs in the master collection has x64 issues.
The only "officially" 64-bit supported version of Adobe Photoshop is CS4, not sure about the master collection though...as odd as that may sound.
Actually, according to Adobe: These are 64 bit compatible under the master Collection (CS4):
Adobe Photoshop® Extended and Acrobat® Pro natively support 64-bit editions of Windows Vista. Adobe Premiere® Pro, After Effects®, Soundbooth®, Encore®, and Adobe OnLocation™ are certified on 64-bit Windows Vista.
https://store1.adobe.com/cfusion/st...H_US_AC_MC_CS4_B_1&tt=H_US_AC_MC_CS4_B_1&nr=0#
At any rate I would check to with Adobe about the CS3 Master Collection.
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
Alpha Wolf, I think you've got some other error not related to Adobe. I've never seen that before. There are varying degrees of problems (mine installed without a hitch) but I've never seen them ALL fail like that. Maybe a reinstall of windows might help.
Is there anything odd or unusual about your computer or was it just bought at the store?
    Intel Q6600 OC'd to 3.2Ghz
    Asus P5B Deluxe
    8GB G.Skill 800Mhz, 5-5-5-15
    Nvidia 9600GT
    Dual Asus VW222U 22" LCD
    1x Samsung 320GB HD321KJ (OS) 2x Western Digital 640GB WD6400AAKS (storage) 1x Seagate 250GB (external backup)
    OCZ StealthStream 600W
    Zalman 9700
I thought that may be you like to know that I don't have any problem installing and using Photoshop CS3 in my 64 bit Ultimate system.
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
I just had this happen to a friend and once he turned Windows Defender off it installed! I hope this works. I tested it by turning defender on and uploads were slow and stripped. Turned it off and it worked right, Coincidence? I think NOT!
    HP Pavillion Elite M9350F
    AMD Phenom X4 9850 Quad
    NVIDIA GeForce 8200 Chipset
    6GB
    NVIDIA GeForce 9800GT graphics card 512MB dedicated
    High Definition Audio
    LG 22"
    Internal: 750GB 7200 160GB 7200 External: WD 500GB
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
    Canon MP500 Printer 3-n-1 Dell 5.1 Sound
