Personal User Shell Folders - Move Location
How to Change a Personal User Folder Location in Vista
The personal user folders can be redirected to, and all files inside them, another partition, hard drive, or folder location to be stored in instead. The folder will still be in the (user name) location in the Start Menu as usual, but it will act like a shortcut to the new location instead.
This can be handy if you would like to save space on the drive or partition with Vista on it, or you prefer to just store the files in the use folders at another location.
If a personal user folder has been deleted, is missing, or does not work propely, then see: How to Restore a Missing Personal User Folder in Vista
  • If you have a program that places a folder in one these user folders, like the Documents folder, then you do not want to change it's location until you change the setting in the program to use another folder or the new personal folder location. Deleting the program's folder usually does not do any good. It will just be added back by the program. If you do not, then you will have two undeletable copies of the user folder. Example: Windows Live Messenger puts and uses a folder in the Documents folder.
  • If you change the Favorites folder location, it will no longer show work from within IE7 unless you change the permission level of the new Favorites folder to give Authenticated User full control. For how, see: How to Change Folder Permissions
  • If you use Windows Mail or any other email program that uses the Vista C:\Users\(user name)\Contacts folder for contacts, then do not change the Contacts folder default location to keep using Contacts in these programs.
EXAMPLE: Personal User Profile Folder Icons
NOTE:
Location is at C:\Users\(User Name)
METHOD ONE
Through the User Folder Properties
1. Right click on a personal user folder and click Properties.​
NOTE: Open the Start menu and click on the username button to see them.
2. Click on the Location tab. (See screenshot below)​
3. To Find the Personal User Folder Location
A) Click the Find Target button. (See screenshot above)​
NOTE: This will open a window with the personal user folder location. You will see the full path of the location above the three buttons.
4. To Change the Personal User Folder Location
A) Click the Move button. (See screenshot above)​
B) Navigate to the location you want to use to redirect the personal user folder to. (See screenshot below)​
C) Right click on a empty area in the Select a Destination window and click New and Folder.​
D) Rename the New Folder to the same name as the personal user folder and leave it highlighted, then click on the Select Folder button.​
WARNING: Do not select another personal user folder to redirect this personal user folder to. You will not be able to use the Restore Default location option. Only use a New Folder.​
E) Click OK. (See screenshot below step 2)​
NOTE: You should see the new full path location above the three buttons.
F) Click Yes. (See screenshot below)​
NOTE: This will move all the files inside the personal user folder to the new location.
WARNING: If you do not click Yes, then you will have two copies of the personal user folder in the (your username) folder.​
5. To Restore the Default Personal User Folder Location
A) For how, see OPTION TWO here: How to Restore a Missing Personal User Folder in Vista
METHOD TWO
Through the Registry Editor
This method will show you how to change only the Downloads (long number), Desktop, Documents (Personal), Favorites, Music (My Music), Pictures (My Pictures), or Video (My Videos) user folder default locations.
1. Go to the location in Windows Explorer for where you want to move the user folder location to.​
NOTE: For example, in C:\Program Files.​
WARNING: Do not select another personal user folder to redirect this personal user folder to. You will not be able to use the Restore Default location option.​
A) Right click on a empty area in the window and click on New and Folder. (See screenshot below)​
B) Leave the folder named New Folder.​
NOTE: This new folder example location of C:\Program Files\New Folder will be used and replaced by the user folder.​
C) Leave this window open.​
2. Open the Start menu.​
3. In the white line (Start Search) area, type regedit and press Enter.​
4. In regedit, go to: (See screenshot below 5)​
NOTE: You can see the default paths for the user folders under the Data column.​
Code:
[/INDENT]
[INDENT]HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders[/INDENT]
[INDENT]
5. In the right pane, right click on the personal user folder you want to change the location for and click on Modify.​
6. To Change the Personal User Folder Location
A) Type in the full path of the new location with the New Folder, and click on OK. (See screenshot below)​
NOTE: For example, C:\Program Files\New Folder.​
B) The registry will now look like this. (See screenshot below)​
C) Close regedit.​
D) Go back to the new location in step 1 above.​
E) Right click on New Folder and click Rename. (See screenshot below step 1C)​
F) Type in the name (EX: Music) of the user folder you want to change the location of, and press Enter.​
NOTE: The folder will now change to the special green color with the name of the user folder.
G) Open the Start menu, and click on your username folder button.​
NOTE: You will see two of these user folders (EX: Music) with the same name now.​
H) Right click on each one separately and click Properties.​
I) Delete the one that does not have the Locations tab in the Properties window. (See screenshots below)​
7. To Restore the Default Personal User Folder Location -
Ok, I don't want to be a hater, but these directions were horrible. There needs to be a thread with directions on how to restore the folders if the user knows they have been deleted.
Here they are:
Go to Run Menu (Winkey+r)
Type Shell:nameoffolder (ex, Shell:Music, or Shell:Pictures)
If that doesn't do it, go to Regedit
Ensure that the the folder you want to fix looks like this %USERPROFILE%\nameoffolder
If not make it that way by right clicking and then hit Modify
Then restart computer,
Then do the shell command
Open Run Menu
Shell:nameoffolder
Voila
Now I could sit here and make them more detailed, but I just wanted to prove a quick point. Those directions were a pile of spaghetti wrapped in an enigma on top of a conundrum served with riddles.
JC
Hi JC,
Thank you for your suggestion. It probably will be easier to understand if the tutorial was split into two separate ones instead. This tutorial was meant mostly for relocating a user folder, and how to restore it back. I'll get on it hopefully soon.
A follow-up question. I have all of the personal files safely moved to a different partition. Complete with green folder and the original folder name in explorer and Office 2007 programs. But...in some programs, the folder is identified as new1, new2, etc.. I don't suppose there is a way to change that, is there?
DonH,
Interesting. What programs are these showing up like this? Any particular user folder they ID as this?
Shawn,
The programs that I notice it in are Edit Pad Pro, Dreamweaver, and other programs that display the full path to a file on a status bar rather than use the vista navigation box. I can navigate to, say Documents, and see the junction in the file drop down dialogs. It's when the programs use the full path outside of the vista templates that they show as "new1" or whatever number.
Don
That's what I thought Don. The programs seem like they are still trying to place their folder inside of the default user folder location causing this "new1". Is there a option in the programs to change the location to where it places it's folder? If so, change it to the same location that you moved the user folder to. If not, then you are stuck with the "new1" unless you move that one user folder back to the default location.
In XP, the My Pictures, My Music and My Videos were all inside the My Documents folder, correct?
What I did in Vista in make the Documents folder the whole partition(D) and then create new folders inside that for the Pictures, Music and Video folders. This should be OK right?
    Intel Q6600 2.4Ghz
    Gigabyte EP35-DS3L
    G.Skill DDR2 1000 2x2GB
    Zotac 8800GTS 320
    Western Digital 640GB WD6400AAKS
Hi Ford GT,
I'm not sure it is like that or not in XP.
For Vista, this will not be ok though. Each user folder needs to have it's own folder in the C:\Users\(user name) folder only and not inside any other user folder. Placing them inside other user folders like Documents will cause problems.
You can move these folder's location to the D: partition as separate folders if you want to though.
Right, I have them so when something is added or changed in the folders it's redirected to my D: partition instead of the C: partition.
    Intel Q6600 2.4Ghz
    Gigabyte EP35-DS3L
    Zotac 8800GTS 320
Ford GT,
Sounds good as long as they are separated. :geek:
I'm posting this for posterity's sake:
Upon changing the Desktop shell folder to the root of a drive, some desktop related settings refuse to persist. This was never a problem with XP, which handled the drive root without incident. The issue persists no matter how the operation is preformed: according to this tutorial or just right-clicking shell folder. Here are the symptoms:
  • Desktop icons always revert to "medium" size and float to the left of my desktop
  • Pinned Start menu items added through Taskbar and Star Menu Properties > Customize... > Show on Start Menu disappear, and will not persist even after pressing "OK".
Service Pack 1 saw these issues non-persistent after rebooting during installation (i.e. the desktop had "large" icons and were in the top row, as I had left it, after rebooting). However, manual shut down since still demonstrates the issues.
I have made a workaround by turning off my desktop icons and making a toolbar at the bottom of my screen containing those folders:
However, after doing that, my toolbars and their icons refused to stay where I left them. Only after many, many reboots did things (slowly) start to stay where I left them, almost one-by-one. As of today, everything is where it should be, but if I tried to move anything it would revert to today's settings.
So if anyone tries moving their Desktop shell folder to a drive root and it's not to your satisfaction, you're not alone.
    HP DV8000
    AMD Turion 64 Mobile (2.20GHz)
    HP 430180-001
    2GB SDRAM w/ 4GB ReadyBoost, 256MB Video RAM
    ATI Radeon Xpress 200M
    internal
    internal
    1680 x 1050
    3 120GB (2 internal, 1 ex.) and a 1TB external (all Western Digital)
    internal
    Black like a stallion with silver trim.
    I tilt my laptop up from the back...
    Microsoft Wireless Notebook Optical Mouse 4000
    internal 104-key Windows QWERTY
    um...fast?
    My computer is pretty.
Brink,
I just realized that you had replied to my May post. I think it's a case of not fully understanding how Vista handles (or shows) the redirects. If I'm remembering correctly, when I named the new folder on the D: drive, that folder was the normal yellow folder icon. When I just created a new folder on D: and left it named new folder, it then displayed the appropriate green personal folder icon. But, the underlying name was still new1 or new2.
I like having the green personal folder icon displayed on D:, but I don't like having the underlying name be the undescriptive new1, etc. Am I misunderstanding how this works? Some days, Vista makes me feel like a total newbie.
Hi DonH,
Strange, it should change the name of the New Folder to the name of the user folder when you select the New folder and change the location of the user folder to it.
Try renaming the new folder to the same name as the use folder to see if that helps.
Shawn,
It is strange. I can right click to change the name to Documents. It looks great in Windows Explorer. But, if I look at the properties of the junction, it shows the location as D:\New Folder. Pictures shows the location as D:\New Folder (3).
It is that underlying folder name that is passed to some programs. :-(
DonH,
It will keep the original name it took over as reference in Location. To have the name you want instead, restore the default location. When you create the New Folder, name it to Documents this time instead of leaving it as New Folder, then change the location to it. You will then have D:\Documents in Location.
Shawn,
Many thanks. It worked just as I thought it should when I first tried. I have no idea why I had so much trouble. Now, if I can just figure out what Vista Backup means by "Documents", I'll be all set! You'd think that somewhere that would be better defined. Documents as in the contents of the personal folder, Documents? Or documents as in those files with certain extensions? <grin>
Thanks again!
Don
Your welcome Don. I'm happy to hear that it us the way you wanted it now.
The backup files option for Documents is for all document type files on your computer, not just the ones in the Documents folder. The screenshot below step 6 of this tutorial will show you what you see for it.
http://www.vistax64.com/tutorials/100133-backup-files.html
I hope that this is an appropriate place to ask this question. I work for a relatively small community college and we are trying to change a single lab over to Vista. (We are using Novell and not Active Directory) On XP, we currently use a simple registry change to redirect My Documents and Favorites over to a mapped network drive. I can see that this isn't as easy to do this with Vista. Right now I am looking at doing the redirection in the image with the Default user and such.
My Documents can be redirected just fine with Method 1 of your tutorial. The problem I am running in to though is that when I use method 1 in your tutorial, I can't get the favorites to show up in Internet Explorer 7. If I go to favorites in the User Folder list, I can see the favorites just fine and they are residing on the proper folder on the network. The location in the properties of the user folder favorites also shows the proper path. I have tried using both the mapped drive letter path to the proper folder as well as the UNC path. No matter what I try, the favorites never show in IE7 unless I move the favorites folder off of the network and back to the local machine. Is there anything I can do to make this work or will we just have to do without having the users favorites show up properly in Vista?
    P D 2800
    Intel 945GCZ
Hi Elangomatt,
I'm afraid that I do not know of a way to get Favorites to work in IE7 unless it is set at it's default location. I looked through the registry in the HKCU and HKLM locations for IE7, but I didn't see anything to specify a path for Favorites.
Sorry, :(
