I just read this article over on LifeHacker.com. It could be of some interest for you as well. Enjoy.
Mythbusting: Debunking Common Windows Performance Tweaking Myths
InformationBy default, Vista reserves 20 percent of the connection bandwidth for QoS traffic handled by the QoS Packet Scheduler. The reserved bandwidth is still available to all programs though unless a program, for example Windows Update, specifically requests priority bandwidth. Vista will then restrict the best effort traffic to 80 percent of the bandwidth to the other programs so that high priority traffic, for example Windows Update, can be accommodated. This will show you how to change the percentage of reserved bandwidth, or disable the reserved bandwidth to get back the full bandwidth so that everything will share all of the available bandwith all of the time.
Hello Ripbox,
Please be sure that you read the entire tutorial before making a statement like that:
http://www.vistax64.com/tutorials/109326-qos-bandwidth-reserve-limit.html
However, I will update the tutorial to help clarify it even more.
Thank you for bringing this to my attention,
I personally don't do every tweak out there for Vista, as if I did, I would have a royally messed up system, to the point, I would have to reformat and reinstall Vista 64.
anyone else do the tweak to make vista use all 4mb of ur l2 cache? i get an increase in my performance score so that one must make a diff
Which tweak is this? Do you have a link?
