PCI E X-16 slot help me out please.
I built my Gaming Rig back in December of 2007 with the help of a friend, spent about 1500 for it (see my PC specs below to see what I got), so far, I have updated my video card twice (once would have been enough really!) and my CPU once. Right now, I am about to update my PSU, which I probably don't need but I want to try something new so might as well.
If I had to do it all over again, I would take a little more time when doing upgrades and/or spend a little more money to get a better upgrade... I'll explain.
My first upgrade was to go from the E6300 CPU to the E7200, not much difference there as far as performance is concern and even though I can OC both of them to really good clocks, I tend to not do so because of temps issues after a few days of heavy gaming use.
I went from two BFG 7800 GTX in SLI to a ECS 8800GT 512MB, again, I didn't see that much as far as frame rates or Maxing out any of the games I was playing. I know went for a GTX260 and the increases are minimum.
Being said that, the negligent increases could be because of other problems I have with my PC but, since I am not a PC Guru, I don't know what could be causing the problem with the big increases.
One thing I know is for sure, I will not spend money on hardware to use in the distant future because, in 3 months time, newer components will come out and what I bought will decrease in price tremendously. I have learn that it is better to purchase right when you are ready and just wait for the right moment to buy. I use 2 sites to check for good deals on a daily basis just to window shop... this is how I got a good deal on the new PSU ;)
Sorry for the rant, guess my kids are not lying when they tell me that I tend to rant on like there is no tomorrow :o
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
I know you're right AstaLaVista, just when you think you have the greatest thing you can afford...it's outdated. I am going to start building my own systems from now on. It's got to be the best way to do it. You get the experience and are able to upgrade when you feel like it. Thanks for the thought.
    The Terminator
    Core 2 Quad
    Gigabyte EP45-UD3P
    4X2GB GSkill 1066Mhz
    GeForce 9500 GT
    Realtek
    Samsung SyncMaster 932 bw 19" and Syncmaster 2033 20"
    1440 X 900 and 1600 X 900
    Patriot Torqx 128GB SSD WD Black 640GB
    Corsair 750HX
    Lian Li PC-B70
    Arctic Cooling Freezer Pro 7
    Microsoft wireless laser mouse 5000
    An old e-machines PS-2 (I have HUGE fingers and it works)
    7 Mps
I trust what I've been told here but I'm about to try this out and this is what HP says about my graphics.
Video graphics
Integrated graphics using nVidia GeForce 6150SE
Also supports PCI Express x16 graphics cards*
NOTE: *Either integrated graphics or the PCI Express x16 slot are usable at one time; they are not usable concurrently.
I just want to make sure I don't need to disable the integrated graphics. Maybe it detects a card and disables itself. Any thoughts?
    The Terminator
    Core 2 Quad
    Gigabyte EP45-UD3P
    GeForce 9500 GT
    Realtek
    Corsair 750HX
    Lian Li PC-B70
    7 Mps
it should disable itself
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
Cool, I guess I'm trying out the GeForce 9600 GT. I'm diving into it now. Thanks!
    The Terminator
    Core 2 Quad
    Gigabyte EP45-UD3P
    GeForce 9500 GT
    Realtek
    Corsair 750HX
    Lian Li PC-B70
    7 Mps
Guys, I'm back and doing my other computer now. All I want is to hook up 2 monitors. Right now I have just one VGA port. I DO need a new card right. There is now other way to hook up monitors? I was just looking at something like this. What do you think?
Newegg.com - ASUS EN6200LE TC1G/TD/512M GeForce 6200LE 512MB 64-bit GDDR2 PCI Express x16 Video Card - Desktop Graphics / Video Cards
Update: I got the answer off another forum / resources. Thanks. I need a cheap video card like the one above.
    The Terminator
    Core 2 Quad
    Gigabyte EP45-UD3P
    GeForce 9500 GT
    Realtek
    Corsair 750HX
    Lian Li PC-B70
    7 Mps
Well, the card sucks, but as long as you are not gaming, it will be fine.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
never get an LE card, they are rubbish, (LE is lite edition) if anything, look toward getting a GT model, any GT model is good regardless of the card type, i used to have a 7600GT 256Mb and it was awesome, quite good and very cheap. but before that i had a 7300GS which is virtually identical to that 6200LE it couldnt even play call of duty:united offensive smooth, ive just also realised that you will see no performance increase with that card, the onboard card you have is 6150SE, this card you want is effectively worse than the onboard one.
this is what you want, its double the price but it will also make sure you wont need to upgrade again in a few months time http://www.newegg.com/Product/Product.aspx?Item=N82E16814130395
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
    The Terminator
    Core 2 Quad
    Gigabyte EP45-UD3P
    GeForce 9500 GT
    Realtek
    Corsair 750HX
    Lian Li PC-B70
    7 Mps
Thank you. How are the GS models. I would like to get something better than what I have but just want to plug in a second monitor. How about this one? How are the GS models?
Newegg.com - EVGA 256-P2-N732-LR GeForce 8400 GS 256MB 64-bit GDDR2 PCI Express x16 Video Card - Desktop Graphics / Video Cards
I am trying to get around my 300W PSU. This one says 350 min. Am I going to have problems?
shouldnt be a problem, i managed to run my p4 3ghz, 2gb ddr ram and 7600gt off a 300w, i dont think you will have any probs with that.
    16Mb Sky bb
