You should upgrade or use an
alternative browser .
Solved partition and clean help
amd 64x2 4200+ 2.2ghz per core
ECS NETTLE
3 gb
nvdia 6150se nforce 430(old rig, upgrading)
reltrek hd audio
hp w1907
1440x968/1024x768
320gb
upgrading, Coolmax CA-450 450watts
hp casing
defult..
hp
hp
768kbps down and 128 up...very slow..
not great compared to other people..
hiya brink. well i did a macrium reflect back up of my drive. and now how will i install it again on another partion? i have the dvds.
ECS NETTLE
3 gb
reltrek hd audio
hp w1907
1440x968/1024x768
320gb
hp casing
defult..
hp
hp
Hi kiddieboy,
To restore the Macrium image, boot the Macrium cd - it will load into Ram . Then you can take the cd out.
Tell the program where the image is and where to restore it to and click finish - it will restore the image to the target partition you asked it to.
If you stored the image on dvd's , you have to put the last one in first.
Macrium Reflect - Blogs and News
Hope it helps
SIW2
Operating System
Vista
Intel E8400
ASRock1333-GLAN R2.0
4gb DDR2 800
nvidia 9500GT 1gb
Operating System
win7/vista
intel i5-8400
gigabyte b365m ds3h
ballistix 2x8gb 3200
ram??? and how do i boot in it? and why do i have to put 2 over one?
ECS NETTLE
3 gb
reltrek hd audio
hp w1907
1440x968/1024x768
320gb
hp casing
defult..
hp
hp
When you boot the Macrium restore cd, it loads itself into memory - that means you can the take the cd out - in case you need to put dvd's in the drive - if you have stored the image on dvd's.
I don't understand that question .
SIW2
Operating System
Vista
Intel E8400
4gb DDR2 800
nvidia 9500GT 1gb
Operating System
win7/vista
intel i5-8400
gigabyte b365m ds3h
oh. usaid i have to put the second dvd first before the first one rite? so i asked why?
ECS NETTLE
3 gb
reltrek hd audio
hp w1907
1440x968/1024x768
320gb
hp casing
defult..
hp
hp
Kiddieboy,
Usually on backup images, all of the file information needed to restore the backup is stored on the last disc of the backup since there is really no way for it be placed on the the first disc since the backup cannot put file information on the first disc about the others that have not even been burned yet.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
It tells you in the tutorial
You must place the last DVD in the CD tray first. The final part of any image contains the image index.
That Blogs and News link is actually a tutorial on how to restore an image.
Hope it helps
SIW2
Operating System
Vista
Intel E8400
4gb DDR2 800
nvidia 9500GT 1gb
Operating System
win7/vista
intel i5-8400
gigabyte b365m ds3h
ok.. so when i install it.
i will have to put the last dvd on my pc.
reboot.
press esc to get into the boot menue
choose boot with dvd
and then...
ECS NETTLE
3 gb
reltrek hd audio
hp w1907
1440x968/1024x768
320gb
hp casing
defult..
hp
hp
Hope it helps
SIW2
sorry
ECS NETTLE
3 gb
reltrek hd audio
hp w1907
1440x968/1024x768
320gb
hp casing
defult..
hp
hp
Operating System
Vista
Intel E8400
4gb DDR2 800
nvidia 9500GT 1gb
Operating System
win7/vista
intel i5-8400
gigabyte b365m ds3h
kk. i will try. plz cheack back it 3 days.
ECS NETTLE
3 gb
reltrek hd audio
hp w1907
1440x968/1024x768
320gb
hp casing
defult..
hp
hp
kk. im done reformated. my chiness os. it doest reconize it. do i deleted the partion and started over. thread closed
ECS NETTLE
3 gb
reltrek hd audio
hp w1907
1440x968/1024x768
320gb
hp casing
defult..
hp
hp
