overclocking my pc help....NOOb
hey. i saw a system max pc..pretty good. 8gb memory
quad core 2.2ghz per core
    amd 64x2 4200+ 2.2ghz per core
    ECS NETTLE
    3 gb
    nvdia 6150se nforce 430(old rig, upgrading)
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    upgrading, Coolmax CA-450 450watts
    hp casing
    defult..
    hp
    hp
    768kbps down and 128 up...very slow..
    not great compared to other people..
it was like 699 usd. no display
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
You don't need 8GB RAM unless you are a professional photo editor in which case you need more 16GB RAM, server board and 2 Xeon CPUs.
Core i7 CPUs are quad core, capable of 8 processing threads. The one I put in my list is 2.66GHz, the one you found is probably from the Core 2 Quad series thus slower regardless of the clocked speed.
A CPU from the Core 2 series, no matter how highly clocked, is and will perform slower than a Core i7 CPU. The Core i7 is completely redesigned, making FSBs obsolete and allowing for MUCH higher RAM bandwidth and clocks, 11GB\s compared to 32GB\s.
Core i7's will overclock better because they are 45nm whereas the Core 2 Quads are normally 65nm, some are 45nm but even then they are slower and less overclock able than the Core i7 series.
EDIT: NOTE - Try to edit previous posts instead of making 3-4 one-line posts in a row. Makes the thread cleaner.
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Coolermaster Silent Pro 700M
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
    Graphics Driver - 190.38
hey. im back. what graphic card will help. i do have a pci express x16 slot empty. any under 50$
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
Re: overclocking my pc help....N00b
Hey,
$50 USD, AUD, NZD? What country are you living in?
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
usd of couse. i was looking and saw a few. i will give you the links. i just dont know what is capatible with my mobo. the ecs nettle
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
hello??..
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
i am aiming at under 70$ plus shipping. nothing much. just for 3d programs. such as 3ds max 2009 . and maybe some games and game engine. i am looking for somthing cheap but i am a total noob. i dont kno which i should get
nVidia Geforce 8300GS 256MB PCI-E (Express) Video card! - eBay (item 310120453065 end time Feb-10-09 18:55:36 PST)
New Palit GeForce 9500GT 1GB PCI Express Video Card - eBay (item 120373456945 end time Feb-10-09 20:40:34 PST)
nVidia GeForce 8600GT 512MB PCI-Express Video card - eBay (item 220358938621 end time Feb-10-09 07:34:52 PST)
i have a ECS NETTLE MOBO
here is the specs i think
Motherboard Specifications, MCP61PM-HM (Nettle)
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
Go for the New Palit GeForce 9500GT 1GB PCI Express Video Card - eBay (item 120373456945 end time Feb-10-09 20:40:34 PST).
It is a good price.
It 'should' go nicely with your motherboard, assuming you found the right description. You could always open your case and look to see if you have one. They look like this http://lib.store.yahoo.net/lib/cooldrives/sata-pci-express-pci-card.jpg or look at the green slots http://www.techpowerup.com/img/07-12-17/780i_right.jpg.
If you still aren't sure just go to PCI Express 16x - Google Image Search.
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
kk. what about the others.
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
As I tell everyone. STAY AWAY FROM ANYTHING under the x600 series cards(9600, 8600, etc) They use DDR2 memory instead of DDR3(And yes, 1GB of GDDR2 memory is SLOWER than 256 or 512mb of GDDR3 memory).
The 8500/9500 and under are poor poor excuses for video cards.
I wouldn't go below the 9 series.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
dd3 is a type of memory right??
anyways my syystem wasent built ddr3
they didnt have that back at 2006
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
kk. i did tell u that i am a noob. so gddr3 uses no ram.
ddr2 memory does.
gddr3 i suppose is faster that ddr2
rite????//
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
kk. no need for that and also hwo much is it. i have a hack lotta ram 3gb and i only se 1.2gb
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
OK.
Grpahics memory and system memory have no correlation.
What is the highest resolution your are going to play games at 1280x1024 or 1440x900?
What games are you planning on playing? Crysis/Warhead, FC2, GTA IV, Mirrors Edge (very nice game!), etc?
calhounhusker can you please remove your system specs from your sig. The 'My System Specs' is the place to put that information NOT your sig. It junks everybody's screens up and annoys people (like me).
If you are unsure how to change the 'My System Specs' please PM me, a mod or click here <code></code> and click on 'My System Specs'.
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
kiddieboy12 I'm going to be blunt here, from what I have read in this thread (yes, I just read then entire thread, including all of your annoying double, triple, and quad posts bugging for a "quicker answer") you do not know enough about computers to even consider overclocking. Overclocking is one of the most advanced modifications that you can make to your PC, and if you do it wrong you can RUIN your ENTIRE computer system. It also seems that you do not know enough about computers to install a new graphics card without messing up your drivers or system stability.
As it was stated before in this thread, your best bet is to simply go out to a local store that sells computers and buy a computer that is assembled and ready to go. If you're willing to spend the money and you would like a good gaming system, you could visit Alienware and configure a computer there. They will build it with the parts you select and then ship it to you. From there you could start by configuring that system, since Alienware computers generally come with the ability to overclock with a program, and you don't have to modify any BIOS settings. Until you gain some experience building computers and configuring them, I DO NOT recommend attempting to build one and overclock it.
If you want a fairly cheap graphics card upgrade still, I recommend an Nvidia based 9800 GT card. It doesn't sound like you need the 1GB memory version, so I'd recommend the 512MB version.
    Acropolis
    Intel Core i7-6800k @ 4.0 GHz
    ASUS X99-M WS
    32GB Corsair Vengeance 2x16GB
    ASUS GeForce GTX 1080 STRIX
    ASUS ROG Swift PG278Q
    2x 256GB Samsung 850 Pro (RAID 0) 1x 500GB Samsung 850 Evo 2x Western Digital RED 4TB (RAID 1) 50TB File Server (Multiple RAID 6)
    Corsair AX1200i
    Corsair Air 240
    Logitech G502
    Razer Blackwidow X Chroma
    250Mbps Down | 15 Mbps Up
