Office file opening problem
vistab0y
I have a problem with office on 2 of my Pc's (Vista x64 & MCE2005) If I double click on any office file e.g. Spreadsheet.xlsx document.docx Nothing happens. Instead I must open them from the file (globe) open menu in program.
Ideas anybody?
Which version of office? And have you tried repair or office diagnostics? My friend had repaired the same problem by doing a reinstall but that was at the recomendation of someone else.
You can find Office Diagnostics in the help menu in outlook.
Also in older versions of office you can do this:
Go to Tools menu/Options/General tab Clear the 'Ignore Other Applications' box. But I see no option in 2007
Also check your error logs by;
Left Click on Start Menu.
Right click on Computer and choose manage.
Click on the event viewer.
You now have loads of options to try and pin down what is happening.
Expand the error tab.
Look for things in the last 24 hours.
This may point you in the right direction.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
To run the diagnostics, just type office diagnostics in you vista start search bar ;)
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
