Nvidia Control Panel Crashing..
Is that 3dmark 06? And is SLI actually being detected? It was never detected for me, and after looking on the Internet, was the same for a lot of people. When you look in system information, it says linked display adapters is false.
So that 21k would be just a single card.
You should get a decent score on 3dmark Vantage, though. SLI works great on that. I get about double the score over my single 8800GTS 512.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Yea, well mark06 is more CPU than GFX. I'll run vantage tonight.
    Q9650 E0 4.0 GHz @1.304v
    eVGA 750i FTW
    eVGA/MSI GTX 260 SLI
    X-Fi XtremeGamer
    Samsung T240 & 226BW
    1920x1200 & 1680x1050
    PC P&C 750w Silencer PSU
    Logitech MX-518
    Logitech G11
This is wierd, I tried going to my registry in vista x64, just to check the access for future problems and I can get to Hkey Local Machine but I CAN'T find current control set.
Of course, coming from XP and being new to Vista, I am getting to the registry from Start>Startsearch>regedit... is that the correct way to get to the registry in vista?
I know that it wouldn't matter but, now I am worried that if this happens to me again, I will not be able to solve the problem and having a band-aid is just that... a temporary band-aid!
Also, are we to delete the whole folder of Nvcontrol panel or just the files inside the folder? just making sure before I mess my whole OS ;) :P
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
Current Control Set should be in HKEY_LOCAL_MACHINE>SYSTEM>CurrentControlSet, but there's no Nvidia related items in the bit that's listed on that guru3d website.
There is a load of Nvidia stuff in the Services section under CurrentControlSet, though.
    ASUS Xonar DX
    100Mbps
You are correct, I think that was for XP and not for Vista.
Well, as luck (or lack off) would have it, my NVCP just took a dump on me when I went to 3D Settings, I can't believe this, it was working fine a few days ago.
this time, it gave me a BSOD that would never recover and I had to use a hard boot to bring it back.
*** STOP: 0x00000101 (0x0000000000000061, 0x0000000000000000, 0xFFFFFA60005E5180, 0X0000000000000001).
I Googled the 0x00000101 error and it appears to be something with shader 4.0 instead of shader 3, also about overcloc issues with video card (which mine is not).
I really don't know why Nvidia has not come up with a real fix for it, according to the forums I found with crash probles, this has been around since 2006.:confused:
Well... back to the drawing board for me I guess.
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
Anybody has any other ideas here? I am going to try to uninstall everything again and install NVCP first and then the video drivers but this is getting to the point where I want to kill someone at Nvidia. :(
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
Altavista,
I believe u need to uninstall all the driver. Use CC cleaner and driver sweeper to clean ur file and register. u don't have to run safe mode. by clicking the same file it will uninstall the driver. remember please uninstall latest driver. try download nov geforce driver and older system tools . see wheter is it working ?
You know, I am getting a bit miffed at all this uninstalling and installing new nvidia drivers. I have never used ATI before in my life but it sure looks like I should be looking to invest on one on my next purchase ;)
At any rate, I will uninstall both video card & NVCP drivers tomorrow and install fresh copies.
Would you advise I install the NVCP first or after the video drivers?
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
ya, I was ready to go ATI.. lol
    eVGA 750i FTW
    X-Fi XtremeGamer
    Logitech MX-518
    Logitech G11
