Solved Not sure where to turn....
sahelms
Hey all, I'm new here.
I know this isn't exactly Vista related, buy you all seem so smart here.
My question is... I have a Gateway m 6309 laptop with a SD/MMC/MS/xD slot. I try to insert my SD card from my digital camera, but it won't go in. At all. It also looks as if there is something inside the slot, blocking it. It's been that way ever since I got the computer, but I've never really found anywhere to ask this question before.
Any ideas?
Hello sahelms & welcome to Vista Forums.
Is your computer still within the Warranty period?
I would suggest that it would be a good idea to seek help from Gateway.
Gateway Support: Email Technical Support
    IntelCore 2DuoT8300@2.4GHz x2
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
I honestly have no idea whether it is or not. It was a gift, and was purchased from Best Buy, but was a floor model, since it was the only one left. Could it be possible that the store did something to the SD slot?
JMH is correct. Also, check to see if it will go in with the media turned upside down.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Gonna say something completely out of let field. sometimes they leave a blank adapter in go that you can use all types of media. could you check to see if you can eject it carefully?
ken
    Dell Inspiron E 1405
    2@2.0
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
ken
How would I go about doing that? I've tried sticking my finger in there, and pressing on the piece, but even my tiny fingers are still too big. Maybe some small pointy thing that I can poke with? Like a stylus?
ken
I was able to use a pair of tweezers to pull it out by a tiny little tab that was on the piece of plastic. I feel rather stupid for not thinking of that before, but I didn't want to break anything.
Thank you all for your advice!
Good news & thanks for letting us know. No need to feel stupid - you only asked for help. [ It would have been stupid NOT to have asked.] ;)
Also well done to zigzag 3143 for coming up with some unusual tech advice that worked.:)
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
