Can the sales rep answer a simple question.
Whose that then.?
Why, when you buy a pre-built system from a shop does it inevitably come with either Norton or McAfee pre-installed?
Thats easy, they know which is the best.
Is it because that is the only way for them to sell their products? The other vendors, viz Kaspersky, Avast, Sophos etc don't see the need to market their product(s) in this way. Their reputation is sufficient.
Their "reputation" is keeping off the list of leading systems.
Before you criticise me,
Why should I, you merely asked a question, which I answered truthfully.
I have to admit that I did use NIS2007 last year, but that is the last time I will be using Norton/Symantec products. I had problems installing it - even on a clean install of Vista, it would sometimes register in the Security Center and sometimes it would not. This is despite doing the installation in EXACTLY the same way each time. Another thing - it would not always update properly, sometimes there would be a few days between updates. Even when it did update, it would sometimes fail to install them properly. This year, I am using Kaspersky, and I haven't had a single problem with it.
Dwarf
