Can i use my computer while it is defraging? i.e. to watch a movie
Not recommended, i even pause my AV resident scanning while defragging
you stated you have 200gb of a 300gb utilized which is quite a lot to defrag and you said disk clean up removed 10gb! well you can gaurentee there will be a lot more that needs removed.
I would recommend running Ccleaner but PLEASE!! do not use the Registry cleaner unless you are confident in tampering with the Registry. If you feel tempted google should i use a registry cleaner and research so you can make an informed decision http://www.vistax64.com/software/86472-latest-ccleaner-version-released.html
I Windows is up to date and SP2 is sucessfully installed you can save about another 1Gb by running from an elevated command prompt type: compcln.exe and press enter this will clean out any reminants of the service pack installation.
You may find doing a clean out defrag may run better and a lot faster
oops forgot; if you open disk cleanup & select the more options tab & run system restore & shadow copies this will clean out all your old restore points & leave you with just your most recent one
- Hewlett Packard, compaq presario CQ60-305AU
- AMD Athlon QI-46 2.1 Ghz
- Wistron 303C
- 2048 Mb DDR2 SD Ram
- NVidea GE Go Force 8200M G / 256Mb dedicated grapics memory
- MCP78S NVidea High definition
- 15.6" High Definition Brightview Widescreen
- 1336x768
- Toshiba MK2555GSX ATA
- Synaptics PS2/Touchpad
