no sleep
After I last posted, I tried putting the system to sleep via the sleep button in Vista (not on the keyboard) and, it went to sleep while I was turning off the mouse. Maybe putting it to sleep via the keyboard and waking it up via the mouse reset it. I haven't tried it again (yet).
In regards to the power supply, I wonder if there is a BIOS setting.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
" In regards to the power supply, I wonder if there is a BIOS setting."
no idea. i would not have any idea 1) how to get into BIOS
2) what to look for
3) how to change anything there.
    HP a1720n
    core 2 duo 6300
    3gb
Just for information, I was able to put it to sleep with the mouse again last night.
To get into the BIOS, you would click on Delete (Del) during the start of the POST. I don't have much time right now to look into it. Maybe later.
I'm surprised one of the others hasn't jumped in with some ideas.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I took a look at my BIOS and didn't see anything in regards to the PSU and sleep mode. The only applicable entry concerned what happens when the Power Button is pressed.
I found a website that said if you used the following keystroke sequence- Windows key, right arrow, Enter- in Vista, it would put it to sleep. Haven't been able to make it work.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
window key, right arrow, and enter brings up the start menu in my computer. i typically refrain from doing mad dashes of keystokes, because if it does do something, and i did not pay close attention, i could end up with either something i did not want happening (bad), or i would stumble aross something i did like, and then i would spend countless time to get it to repeat.
    HP a1720n
    core 2 duo 6300
    3gb
Run Ctrl-Alt-Delete. In the right hand bottom corner, choose sleep. If that works, then I suggest waking it up using your mouse and then try the normal Start, Shut Down, Sleep.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
