You should upgrade or use an
alternative browser.
no problem, just need help deciding.
maybe you could run the disk defrag that might help a little
- Acer, Aspire M1201\Custom Build
- AMD Athlon X2 5000+ @ 2.6Ghz
- Acer Micro-ATX Motherboard
- 2x2gb Patriot Viper DDR2 PC6400 @ 800mhz Dual Channel SLI Edition (4-4-4-12)
- ATI HD3870 with 512mb GDDR4
- Realtek HD 7.1 Onboard Sound
- 22" Acer X223 Widescreen
- 1680 X 1050
- 320gb Western Digital SATA II (Ubuntu 9.10)
500gb Seagate SATA II
- PSU
- ULTRA X3 600 Watt Modular
- Case
- NZXT Tempest (The Airflow King) 2x 140mm Fans, 4x 120mm Fans
- Cooling
- 1x 135mm In PSU, 1x 70mm On CPU, And 1x 120mm On GPU
- Microsoft Sidewinder X5
- Microsoft Sidewinder X6
- 6 Mbs Down 1 Mbs Up
- Other Info
- AVerMedia 1500MCE TV Tuner
Seven Guru + GFX
Power User
yh ok
i have done it before, but i'll try again anyway
- Acer 5735z Laptop
- 2.0 ghz intel pentium dual-core processor t4200 800mhz fsb
- Acer CathedralPeak Rev
- 4gb
- Integrated Intel Graphics Media Accelerator 4500
- Realtek
- 15.6" HD CineCrystal LCD
- 1366x768
- 160gb stock drive. ATA
- Case
- Stock Notebook
- Cooling
- Stock
- Synaptics TouchPad
- PS/2
- No idea
Seven Guru + GFX
Power User
it says the system is fine
- Acer 5735z Laptop
- 4gb
- Realtek
- 1366x768
- Case
- Stock Notebook
- Cooling
- Stock
- PS/2
- No idea
um..... maybe clean out some temp files and stuff like that?
- 1680 X 1050
- PSU
- Case
- Cooling
- Other Info
Seven Guru + GFX
Power User
- Acer 5735z Laptop
- 4gb
- Realtek
- 1366x768
- Case
- Stock Notebook
- Cooling
- Stock
- PS/2
- No idea
